Old August 4th, 2003   #1 (permalink)
Name: yuthana subpaya-achin
Thailand Send a message via ICQ to UTGolf Send a message via MSN to UTGolf Send a message via Skype™ to UTGolf
Exclamation
i have a problum.last time i buy new one cpu p4 it a standart.and i install light scape 3.2 in this cpu normaly finnish.and i run lightscape program but not work.it show Failed to creatempty document.how to do for work.
last cpu i use program in notebook p3 on fujitsu.
i can use .
UTGolf is offline
Old August 4th, 2003   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
If I remember from past problems, it may be an issue with the display driver. You would need to experiment with different version drivers to find one that works.
Which OS on the new computer?
To test if it is the driver, set your display mode to 8 bit color (256 colors) and try again to start Lightscape. If it starts then you definately have a driver problem. In 8 bit color everything will look very bad, but it should at least open and run.
If it still does not run, post more information
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old August 4th, 2003   #3 (permalink)
Thank you very much for your answer.
i change vga card to 8 bit 256 colour now.
but it can't to display show me anything on my monitor.i can't change back. how i can do this.
thank you
UTGolf is offline
Old August 4th, 2003   #4 (permalink)
I have to turn down the hardware acceleration on my ATI card for LS to run.
Display props / advanced / trouble shooting
Try the second to the lowest setting. The lowest setting will totally bog down your system. This way you can keep your 24 bit colors.
Joseph Petrino is offline
Old January 2nd, 2004   #5 (permalink)
Talking
I just joined the forum and just recently started using Lightscape after a long abstance.
FYI
I got the error message about the blank form also.
I downloaded the lastest drivers for my system and if fixed the problem.
Scot
scota is offline
