Old March 20th, 2008   #1 (permalink)
Default is it the time to shift from max 9 to max 2008
is it the time to switch from max9 to max2008
which is better out of the 2
we are using 64 bit windows and quad core machine
Shall we shift to max 2008? is it worth it?
i hope there are no directx problems with it or any other max plugins
we will be using
vray
egz materials
onyx tree storm
particle flow
real flow
glu 3d
are the out for 2008 64 bit version
3dsmaxed is offline
Old March 20th, 2008   #2 (permalink)
Default Re: is it the time to shift from max 9 to max 2008
Unless there's a feature you really need in 2008, the argument for upgrading isn't very strong.
DavidR is offline
Old March 20th, 2008   #3 (permalink)
We haven't yet, but this thread did catch my eye.
http://forums.cgsociety.org/showthre...AX+2008+Stable
I guess it depends on who you believe....
Jon Kletzien
StudioAMD Inc.
Website
jkletzien is offline
Old March 20th, 2008   #4 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
I would just check with Nextlimit and Glu3D guys, as they're historically not the fastest to update their stuff
I've been using 08 for some smaller projects to test so far and its been running perfectly here. (Once you get rid of the new select by name crap)
I do find it very noticeably faster in the viewport.
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Old March 20th, 2008   #5 (permalink)
yeah they have really messed up the new select by name appearance.
How to get rid of that?
3dsmaxed is offline
Old March 20th, 2008   #6 (permalink)
mattclinch's Avatar
England  Send a message via MSN to mattclinch
Go to the location of your CurrentDefaults.ini file -
\Application Data\Autodesk\3dsmax\2008 - 64bit\enu\defaults\MAX
Right at the bottom of the ini file (CurrentDefaults.ini) you will find the string:
[Scene Explorer]
SelectByNameUsesSceneExplorer=1
Change to:
[Scene Explorer]
SelectByNameUsesSceneExplorer=0
Save and reopen MAX
Never had any issues with 2008. Speed increase was superb on my system and its been solid as a rock stability-wise.
Matt Clinch
Arch Viz Artist @ Hayes Davidson
http://www.hayesdavidson.com
mattclinch is offline
Old March 20th, 2008   #7 (permalink)
Canada  Send a message via MSN to Logitek
Really? My Max 2008 copy has been sitting on my desk for 4-5 months... never had/took the chance to install it in fear something might be messed up in my workflow...
I guess I could/should make the jump now...
Matthieu DELARUE
ARCHIMED STUDIO
www.archimed-studio.com
Logitek is offline
Old April 24th, 2008   #8 (permalink)
[Scene Explorer]
Change to:
[Scene Explorer]
Save and reopen MAX
thanks
that helped
3dsmaxed is offline
Old April 24th, 2008   #9 (permalink)
SandmanNinja's Avatar
I remember reading your original tip, but couldn't find it and wasn't sure who posted it or any particular phrase to search for.
Now that I have Max 2008, I've copied your tip to my Max Notes section.
The new scene picker isn't horrible, but I'm use to the 'old fashioned' way of picking, and I think the new one is a bit slower.
Thanks!
-SandmanNinja
website
SandmanNinja is offline
max 2008 customized settings mesht 3ds Max 0 December 22nd, 2007 08:55 PM
3ds Max 2008 crashes jtroupe 3ds Max 9 December 14th, 2007 07:11 AM
3ds Max 2008 compatible with Max 9? VCRUPI 3ds Max 2 November 18th, 2007 08:11 PM
3ds Max 2008 Review: Boosting Performance Jeff Mottle CGA News 1 October 18th, 2007 03:01 PM
