| 3ds Max Autodesk 3ds Max |
i have a standard way of working with max, but i am not very technical, usually when i open it up i change all of the necessary settings that i like to work with, for example:
render settings: PAL, 250 frames on the timeline, aspect ratio unit settings: millimeters is there anyway of setting all of this up so that it is stored as default without me having to change everything evertime i open it up coz to be quite frank, its getting a bit annoying and boring to say the least now |
Set everything up the way you want, this goes for toolbars, units, snaps, render settings, viewports etc. Then save this to My Documents/3dsmax/scenes to overwrite the file called "maxstart.max".
This file and the settings within will now become your default. |
| gamma settings for max 2008 and photoshop | mesht | Mental Ray | 3 | February 11th, 2008 06:16 PM |
| vray settings | Janrey | VRay Render | 8 | May 4th, 2007 02:07 PM |
| Quiestion About Irradiance Map Saving ........ Pls Help Urgent....! | yogeshwagh | VRay Render | 3 | January 14th, 2007 10:03 PM |
| Colour settings | Dibbers | Photoshop | 2 | November 24th, 2003 04:34 AM |
| Raytrace Settings | Wolf | 3ds Max | 30 | July 31st, 2002 08:44 AM |
