| 3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum. |
Name: Kristian Botnen |
Hi.
I am trying to establish some kind of workflow with XFrog trees exported as .obj and imported into 3ds max 2008. Does anyone have a good workflow for this? Here are the ressult of my effort so far. The overview scene is just to show the lightning setup, it's rendered with some other trees. The palm closeup shows the problem. After going over a lot of the materials and add opacity map according to alpha in bitmap manually it renders something like a palm, at first it as only white where alpha was supposed to be. But it still seems kind of odd with some self.ill going on. Is there a better way to transfer Xfrog models to 3ds max 2008? The old plugins wont work anymore :/ -K- |
Name: Anwar Fardullah |
hi
does your xfrog dvd comes with all the 3d models format? when i purchase mine, it came with all the available 3d models, including .max format. i only export as .obj when i edit the trees parameters in xfrog tune, as modified trees can't save as .max format. you should have .max version of the models that comes with the dvd, that's what i did, just merge the models into my max with mapping already applied, be it ver 9 or 2008. i did not use the plugins though, as i do not need them. |
[quote=mesht;205898]hi
i only export as .obj when i edit the trees parameters in xfrog tune, as modified trees can't save as .max format. That is the problem. But I manage to solve it. There was opacity map assigned to the bark material causing the problem. Thanks for the reply anyway -K- |
Name: Jonas Callewaert |
i bring them in as OBJ and have to flip the Transparency map inverse to make the leafs work
| Tags |
| xfrog |
| finalF/X for 3ds Max 9 and 2008! (finalDOF, Pyrocluster, finalFlares) | candicekulacz | finalRender | 0 | February 15th, 2008 01:54 PM |
| Post Your Wish for 3ds Max in 2008 | Jeff Mottle | CGA News | 0 | December 21st, 2007 12:01 AM |
| 3ds Max 2008 crashes | jtroupe | 3ds Max | 9 | December 14th, 2007 07:11 AM |
| 3DS Max 2008 | daveb867 | 3ds Max | 0 | August 7th, 2007 02:23 AM |
| 3ds Max 8 Service Pack 1 is out | theqball | 3ds Max | 4 | August 10th, 2006 07:12 AM |
