Old May 8th, 2008   #21 (permalink)
SandmanNinja's Avatar
Default Re: What In The World Is Causing This?
VERY NICE!
Glad you got the noise sorted - nice image.
-SandmanNinja
website
SandmanNinja is offline
Old May 8th, 2008   #22 (permalink)
Thanks, Sandman. Unfortunately this particular piece of brew equipment won't even be seen in the final render - that is unless I can convince the developer to pay me for a second shot from the opposite end of the pub. But this let me perfect the material for application to the other brew equipment closer to the foreground of the final shot.
renderhaus is offline
Old May 8th, 2008   #23 (permalink)
shaneis's Avatar
Originally Posted by renderhaus View Post
...I changed my areas to points and took the mr Physical Sky out of use in the background Environment Map (left over after Daylight deleted).
Then Spock-logic suggests the only possible cause is your area lights. Sorry to chime in late, but your problem is most probably because you were using spherical area lights. They "dilute" the samples around the whole scene but by replacing them with disc area lights and setting your high/low samples just right, you're aiming all that sampling info where you want it - on the subject. I often find with problematic area lights that a low sample value of half the high sample value will fix the problems (for eg, try highSamples=64, lowSamples=16/24/32 until your specular smoothes). Not sure about Max options, but in Maya the area light has theses sample channels, highSamples, highSampleLimit, lowSamples. If the highSampleLimit=1, then once the light has "hit" once, it will revert to the lowSamples value, so increasing the lowSample value will retain the quality. On a similar note, if you're using a procedural map for the A&D's reflectivity to generate the brushed effect, filtering the map can also help as the map is what's providing the info that governs how the area light will reflect back to the camera (ie specular info).
S.
shaneis is offline
3D World Magazine - Arch Viz Issue Jeff Mottle General Discussions 33 2 Days Ago 11:54 PM
'Connect' uses real world units derek forreal 3ds Max Wish List 0 January 18th, 2008 08:07 AM
ucs world is wrong alikashan AutoCAD/AutoCAD Architecture 5 May 30th, 2006 04:42 AM
3rd World Memorandum Archmage General Discussions 24 May 18th, 2004 02:27 PM
Learning to see the world. . . garethace General Discussions 4 September 4th, 2003 12:35 AM
