Name: Tiago da Silva |
Hi there,
I need to render 6 frames in order to create a cubic Quicktime VR movie, and I need 3DS Max to save them as .jpg files. However, when I use Maxwell, all the frames are overwritten! I mean, in all 6 rendered frames, max sends the same image name to Maxwell, and I get 6 identic names in the "image" feld, in the render output settings... what do I need to do in order to have all six frames saved as jpg files, and not only the last one? Thx in advance |
Name: Devin Johnston |
Can't you send each of the six images separately giving them different names? It seems simple to me but I might be misunderstanding your questions.
That might be a question for the official Maxwell forum. Maybe there is a command line switch for incremental file names?
Thank you for the answers.
As for sending the images to the render engine separately, this is not possible; they have to be sent in sequence, due to the enormous time they take to render... Gosh, I never imagined that to do simple things in Maxwell such as setting up the light intensity and image sequence rendering would be so complicated... |
#5 (permalink) | |
Name: william york |
| Rendering a wire frame image out of Max | jphelps | General Discussions | 12 | April 4th, 2008 10:19 AM |
| import an 15fps image sequence in AE | Logitek | Compositing Software | 2 | January 9th, 2008 07:06 PM |
| Difference between Max and Maya | whale | General Discussions | 16 | July 20th, 2007 02:08 PM |
| 3DS max 3ds max, it's all i hear about!!!!!! | chalk | General Discussions | 31 | May 30th, 2007 05:23 AM |
| Question to 3ds max users. | Pablo Zurita | 3ds Max | 0 | May 27th, 2005 01:30 PM |
