Old May 6th, 2008   #1 (permalink)
nelpiper's Avatar
Name: nelson fernandes
Default vray 2sided material
Hi guys. I'm working on a scene where I must have lots of those chinese lamps hanging everywhere (those ones that translucency and look like candles). I'm trying to use vray 2sided material but it's not working. On the vray manual, they say that it should be better using it with one sided geometry. Mine is a beveled box (has some thickness to the edges and is extruded inwards). When I apply the vray 2sided material to it and a vray light, it doesn't work. However, when I apply other type of light (not vray), it works but than I can't get the vrayshadows. Does anyone have any idea how to make this work with vray lights? thanks.
nelpiper is offline
Old May 7th, 2008   #2 (permalink)
Woody's Avatar
Default Re: vray 2sided material
Try a shell modifyer on your beveled box. I've found that with transparent objects vray needs a thickness.
Woody is offline
Old May 7th, 2008   #3 (permalink)
nicnic's Avatar
dont try a shell mod. single sided geometry only.
what do you mean the edges have a thickness and are extruded inwards?
whats your 2 sided mat made up of? Its pretty simple to set up.
nicnic is offline
Mental Ray and Vray Proxies Usability Compared crazy homeless guy Mental Ray 10 April 24th, 2008 05:29 PM
Vray Sun system doesn't shine through glass material into room David Ghazawy VRay Render 17 February 29th, 2008 07:55 AM
vray material b, d, and reflectivity own1221 VRay Render 0 February 16th, 2008 01:49 PM
Vray polycarbonate material jorisAR General Discussions 2 December 11th, 2007 03:15 PM
vray material over bright warning aligrafix VRay Render 0 August 24th, 2006 01:40 AM
