Old May 7th, 2008   #1 (permalink)
Default Models Showing in 3d in 2d Layout
I'm working on a viz project for a client and they supplied the 3d models of all the furniture in .dwg format. When I open the files I am in my top view (2d) but the models are showing up isometrically as 3d objects (the plan view furniture is truly 2d only). They are true 3d models but when I switch to a 3d viewport they are rotated and I can't seem to get them to rotate back to the proper orientation. Any ideas?
Also, is there a way to stop the 3d models from re-drawing constantly? I apologize if I should know this but I don't work in ACAD 3d very often.
Thanks,
Sean
thickly is offline
Old May 19th, 2008   #2 (permalink)
neko's Avatar
Default Re: Models Showing in 3d in 2d Layout
it's a little hard to understand the problem, but i suspect it has something to do with paperspace/modelspace
do you want to send me the drawing and i'll have a look for you ?
neko is offline
Real models vs. virtual models oluv Realtime/VR/ Interactive/ VRML 5 March 19th, 2009 07:02 AM
Light fixture models with ies files, copyrights pailhead General Discussions 4 September 9th, 2007 05:35 PM
Hot fashion models - HELP!! smorehouse 3ds Max 10 June 14th, 2006 06:20 AM
Transparent raytrace models Nats 3ds Max 0 January 20th, 2006 12:40 PM
Modeler LayOut Saving Files Hector Lightwave 5 June 5th, 2003 05:35 AM
