Go Back   CGarchitect.com > 3D SOFTWARE > 3D Tree & Plant Software and Anything Vegetation
3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum.
Old May 13th, 2008   #1 (permalink)
New Zealand
Default Treestorm - Replacing sub objects
I just purchased Treestorm and i love it. At the moment i am opacity mapping my leaves but am trying to replace the plates with leaves i have made using the replace sub object setting.
What i am having trouble with is getting the leaves to orientate correctly, if i have the pivot orientated to the 'world' i.e z=up etc, the leaves are all over the place, any suggestions?
dunniz is offline
Old May 13th, 2008   #2 (permalink)
WAcky's Avatar
Default Re: Treestorm - Replacing sub objects
dont use the replace function. You need to read the manual again...
I'd explain it to you but the manual will do it faster and more clearly...
WAcky is offline
Old May 13th, 2008   #3 (permalink)
manta's Avatar
Don't use the replace function...that's what the manual is going to say ??
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old May 13th, 2008   #4 (permalink)
New Zealand
Please do explain, i am away from the office for a few weeks and do not have the manual on my computer. How do i replace the plates with custom objects correctly?
dunniz is offline
Old May 14th, 2008   #5 (permalink)
WAcky's Avatar
Select your tree
Click adjust in the modify rollout
Check the UV box that correspondes with the Leaf parameters
Click Sub-Objects
Start off with 1 (drag the slider across)
Click use plates
Now setup your plates
The three will now detach from the leaves
Apply a texture to the leaves!
WAcky is offline
Old May 14th, 2008   #6 (permalink)
or use replace and just align the pivot's z-axis with the leaf's length, and the x along the base of the leaf and avoid those opacity maps.
Jon Kletzien
StudioAMD Inc.
Website
jkletzien is offline
Old May 15th, 2008   #7 (permalink)
New Zealand
THANKS, that was the information i was looking for
dunniz is offline
Old June 20th, 2008   #8 (permalink)
[FONT='Verdana','sans-serif']I’m sorry but I am new to onyx tree, I tried fallowing the steps outlined in this forum as to replacing leafs with new geometry, but I can't seem to find the Sub-Objects button or tab that WAcky is talking about. [/font]
Originally Posted by WAcky View Post
Select your tree
Click Sub-Objects
Click use plates
[FONT='Verdana','sans-serif'][/font]
[FONT='Verdana','sans-serif'] [/font]
[FONT='Verdana','sans-serif']Reading through this it seems that this is all done in tree storm, yet I can’t find all of the features that people are talking about. I have also check the manual for this feature but I can’t seem to find that section either. Is this something that is done in the modify tab or is this a feature of tree storm? I have been able to apply leafs for mapping but as I am using v-ray I want to reduce my use of opacity maps and really create some nice looking leafs for my trees. [/font]
[FONT='Verdana','sans-serif']Please help me! If anyone knows of a tutorial or can walk me through this I am sure it would not only help me but any one searching for this information on the web.[/font]
[FONT='Verdana','sans-serif']Thanks[/font]
substance_design is offline
Old June 20th, 2008   #9 (permalink)
Well i just received this email from the support staff at Onyx Tree.
"In the latest version of Tree Storm which you have, this feature does not exist any more.
Some customers had reported problems with leaf plates that were related to the intrinsic limits of Autodesk sub-object architecture. We had tried but had not been able to fix these problems. Thus, in the latest Tree Storm for Max 9/2008/2009, the leaf plates as sub-objects are replaced with leaf plates as sub-materials. These leaf plates cannot be replaced with the objects of your choice."
is there another way to replace the leaf plates with geomitry? maybe a round about way i am not thinking of?
Old June 20th, 2008   #10 (permalink)
WAcky's Avatar
interesting.
I guess you will have to collapse your tree mesh and do it all manually?
wow. Another reason not to move up to max 2009?
James Burrell
Pixel Constructions
WAcky is offline
Seleting the objects in camera angle nivvu VRay Render 2 October 4th, 2007 11:37 AM
Seleting the objects in camera angle nivvu 3ds Max 0 October 3rd, 2007 03:03 AM
simplify a model? Robeast Autodesk VIZ 7 May 19th, 2006 06:30 AM
Objects Utility Needed for Max/Viz cgarchist 3ds Max 3 November 23rd, 2005 01:46 AM
Hiding Objects in C4D manepalli Cinema 4D 2 November 26th, 2004 10:12 PM
