Old May 13th, 2008   #1 (permalink)
Default Ground plane overexposed when using VRAY sun
How do I light the ground plane in a scene while using VRAY Sun. I use a VRAY camera and the exposure for everything is right but the ground is blown out. I want the shadows on the ground plane so I cant exclude it from the sun.
parker2740 is offline
Old May 14th, 2008   #2 (permalink)
Name: José Olivares-Hatch
Default Re: Ground plane overexposed when using VRAY sun
Give the ground plane a v-ray material and add a v-ray color map to the diffuse slot. Set the colour you want and then decrease the multiplier to say 0.5 and re-render. Tweak the multiplier until you get a good exposure.
Hope this helps
Mr-JosE is offline
Old May 14th, 2008   #3 (permalink)
Actually I am using a VRAY BMPfilter which seems to be working. Thanks for the help though it was a good start
Mental Ray and Vray Proxies Usability Compared crazy homeless guy Mental Ray 10 April 24th, 2008 05:29 PM
annoying problem with vray sun please help! ncartlidge VRay Render 3 April 15th, 2008 12:56 AM
Does Vray Sun Have to Be Used With Linear Workflow? wizuby VRay Render 17 October 10th, 2007 12:07 PM
Vray - How to exclude objects from Reflection ?? vishesh_12 VRay Render 6 August 27th, 2006 01:53 AM
