Old May 17th, 2008   #1 (permalink)
Default RP's residence
hi
this is my first post...and this is one of my best works.
thanks
warm rgds
naveen
navnow is offline
Old May 17th, 2008   #2 (permalink)
Lebanon
Default Re: RP's residence
nice work although on my screen it looks a bit pale and i think u should add some more detail.keep it up ur on the wright track.
fadi3d is offline
Old May 17th, 2008   #3 (permalink)
thanx for ur comments fadi....
Which portion of the image u think needs more detail?
navnow is offline
Old May 18th, 2008   #4 (permalink)
Horhe's Avatar
Overall looks good.
Some crits:
1) Image seems blurry could use some sharpening
2) It looking too gray I recon. Try adding a yellow/blue tint. A combination of those two colours will get you a more realistic image.
3) The vegetation seems blurry and overall too dim. Might use some brighness/contrast.
4) The compostion looks a bit boring. Too much asphalt is showing - either get a car in or cut some of the road off.
Horhe is offline
Old May 19th, 2008   #5 (permalink)
hi horhe,
thanks for ur response... will keep ur points in mind.
navnow is offline
Residence muchhal.sandeep@gmail.com Work in Progress (WIP) 7 March 25th, 2008 11:45 PM
Hakuei residence kiittea Finished Work 2 February 22nd, 2008 04:48 AM
Run Down Residence Wip cjlopez4 Maxwell Render 2 July 25th, 2007 01:19 PM
[3ds max] Parra Residence cmeraz3d Work in Progress (WIP) 8 June 11th, 2007 11:34 AM
residence : exteriors kippu Finished Work 8 August 8th, 2006 05:18 AM
