Go Back   CGarchitect.com > 3D SOFTWARE > Maya
Maya Alias
Old May 20th, 2008   #1 (permalink)
armir73's Avatar
Name: Le Bihan-Plamondon Armor
Colombia
Smile Hello presentation, first post
Hi i am very glade to found this cgarchi dedicated web site
I hope it will be a long "affaire" with this community.
I present myself:
I am a french guy living in Ibague, Colombia, since one month !
I use to work in audiovisual industry in France.
But cause of the poor devellopment of this professional
branch where i am living actually.
I want to devellope my small knowledge in 3D ( only with Maya !! )
in this special direction that is architectural rendering.
In effect the most solid economical sector over there is
construction and architecture.
So as a very newbie, i will be very glad if somebody
could help me.
For example explain me what is the process, from a autocad plan
construct the 3D elevation of this plan. How can i do , using maya.
Also as i have not study architecture, i don't have any autucad or archicad file
If any one could send me one, just for exercise me to import and
make the elevation.
thank's
armir73 is offline
Old May 20th, 2008   #2 (permalink)
shaneis's Avatar
Default Re: Hello presentation, first post
Which version of Maya do you use?
When importing CAD data, make sure the DirectConnect plugin is installed and loaded (Window>Settings/Preferences>Plug-in Manager) Tick the check-box for "DirectConnect.mll" to "Load" and "Auto load". While you're there, you may as well load "fbxmaya.mll".
Now you can import CAD-type files. As for learning Maya for visualisation, you need to concentrate on efficient modelling (NURBS, Sub-D and Poly), creating textures and shading networks, lighting techniques and rendering with mentalRay.
As for tutorials, the web is full of resources or if you prefer, the DVD's in this kit
http://www.digitaltutors.com/store/p...&cat=72&page=1
will get you up to speed. Bear in mind though, that many of the principles in 3D apply to all programs, so you can learn quite a lot from discussions about 3DS Max and V-Ray, for example.
All the best,
S.
shaneis is offline
Old May 20th, 2008   #3 (permalink)
Name: Jiang Gao Wei
god job
ginsun is offline
Old May 21st, 2008   #4 (permalink)
armir73's Avatar
Colombia
Hello shaneis, ginsun
Thank's a lot for the good welcome in.
And also for the settings info you provide me.
CAD files are 2D plan, top, side, cut inside, is'nt it there ?
There isn't 3D info inside?
Excuse me for this very basic question, but as i had never manipulate
any files of this type.
Do you where i can a CAD file in the web, i have made some research
but it was unsuccesfull at this time
thank's
armir73 is offline
Old May 21st, 2008   #5 (permalink)
shaneis's Avatar
No, there can be 3D data in a CAD file. It all depends on what was exported from the CAD program in the first place.
As for free files, look for "DWG", "DXF", "IGES" or you could make a new thread in the CAD section of this site and ask if anyone could provide you with a simple CAD file to practice with.
S.
shaneis is offline
Old May 21st, 2008   #6 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
try cad block exchange network
cben.net
y maya?
Antisthenes is offline
adding a sky in post daveb867 3ds Max 1 March 25th, 2008 09:03 AM
post your gf/bf here !!! STRAT Off Topic 13 September 18th, 2006 10:00 AM
full screen presentation 3dsmaxed Compositing Software 5 October 30th, 2005 08:33 AM
Rendering a scene with video post Jordy 3ds Max 2 December 2nd, 2004 07:11 PM
