Old May 22nd, 2008   #1 (permalink)
Default mr daylight sky
When I created a MR daylight, then render, there is a sky image automatically appeared on my rendering. It is amazing. I think even VRay don't have this capacity. But my sky is pretty dark even I moved my sun into 12:00 PM noon position. What should I do?
Thanks.
smr_VIZ is offline
Old May 22nd, 2008   #2 (permalink)
manta's Avatar
Default Re: mr daylight sky
pretty much all the render engines have this capacity now...its called a physical sky...you may need to use exposure with MR though...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old May 22nd, 2008   #3 (permalink)
toxic_box's Avatar
Iraq  Send a message via MSN to toxic_box Send a message via Yahoo to toxic_box
Yes Manta That's Right.
smr VIZ Press 8>>>>>then select mr Photographic Exposure control >>>>and then choose a peset >>>> Physically Based Lighting Outdoor Clear sky...
Also Make sure that you have set the gamma/LUT Preferences on the preferences.
Any help don't Hesitate Just PM me
toxic_box is offline
Old May 22nd, 2008   #4 (permalink)
Are you in Max or VIZ? I am using viz 2008 and I can't find "mr Photographic Exposure control "!
smr_VIZ is offline
Old May 24th, 2008   #5 (permalink)
toxic_box's Avatar
Not Exists in VIZ
only max 2008 / max 2009 / Max Design 2009
Also you can render it in Logarthmic Exposure Control.....Render to Open exr and Adjust the exposure in Photoshop.
Cheers
Adding realistic clouds to sky or rendering Timothy Saunders 2D/3D Tutorials 10 August 18th, 2008 07:15 PM
Sky bitmap with daylight system daveb867 Mental Ray 14 March 5th, 2008 05:47 PM
Mental Ray/Image Based Lighting & the Daylight System? Brad_S Mental Ray 4 January 30th, 2008 04:13 PM
to sky or not to sky crazy homeless guy Work in Progress (WIP) 9 October 23rd, 2005 03:39 AM
daylight sky background pipjor 3ds Max 1 October 18th, 2002 06:09 AM
