Cinema 4D Cinema 4D
Old May 28th, 2008   #1 (permalink)
Ireland
Default Moving Objects
Hi
I am just wondering is there a simple method to move an object up on the
y axis a set distance. I currently have an object at position
X = 0, Y= -1003.272, Z = 0.... an want to move the object up 15cm.
Can this be done without having to add the 15cm to the -1003.272?
I tried holding shift down and moving up manually but it moves up at
increpments of 10. Can this be change to increments of 5? And is that
the simplest way of doing this?
ZFact is offline
Old May 28th, 2008   #2 (permalink)
South Africa  Send a message via Skype™ to arnold@asylumstudio.co.za
Default Re: Moving Objects
yeah...there is a easier way... go to bottom of the screen, next to your lock, on the right hand side there is an icon "Absolute mode transform", click on that type in numeric value that you want to move and voila (under Y), oh and make sure you are in the elevation view when you are doing it... That should sort you out...
arnold@asylumstudio.co.za is offline
Old May 28th, 2008   #3 (permalink)
sorry thought you were working in studio max...
Old May 28th, 2008   #4 (permalink)
BillyElNino's Avatar
England
rather than working out what -1003.272 + 15 is and then inputting that in the coordinates box you can click the text cursor in the coordinates box that you want to alter after the text and the unit and type in + (or -) 15 (or whatever number) and hit enter. This will add or subtract the typed in number and edit the position of the object.
Note: My example is obviously in the x axis but this basic adding and subtracting process works in all Cinema 4D numerical boxes.
BillyElNino is offline
Old May 28th, 2008   #5 (permalink)
Ireland
thanks man - great tip
ZFact is offline
Old May 28th, 2008   #6 (permalink)
Frosty's Avatar
United_States  Send a message via MSN to Frosty
Another method is to enable snapping and to quantize the movement - in your case by 5. This will also work for rotates (degrees) and scaling (percentage).
Steve Shaw, M.Arch
www.crucialperception.com
Frosty is offline
Old June 3rd, 2008   #7 (permalink)
Ireland
Thanks Steve;
I read that somwhere else but could not figure out how to change the quantize movement from increments of 10 to 5. Can you let me know please.
Paul
ZFact is offline
Old June 4th, 2008   #8 (permalink)
Frosty's Avatar
Paul,
1) Open the Attributes Pallet and Snap Settings tab.
2) Enable the Move Quantize and set the interval as needed.
Steve Shaw, M.Arch
Frosty is offline
Old June 5th, 2008   #9 (permalink)
Ireland
thanks everyone
ZFact is offline
Old June 6th, 2008   #10 (permalink)
gdrakakis's Avatar
Greece  Send a message via Skype™ to gdrakakis
Originally Posted by ZFact View Post
Hi
hi there are 2 ways i can think of
1) just add +x in the Coords Manager.
x is the moving distance.
c4d will do the math for you.
2) click the move icon, go to Attribute Manager->Snap Settings->quantize->set the desired movement.
this will effect every movement from now on.
hth,
george
edit: sorry, i didn't see the posts above.
i got a new lazy mouse that doesn't like to scroll
gdrakakis is offline
Moving groups of objects to different layer. crazy homeless guy 3ds Max 5 March 13th, 2008 03:55 AM
moving objects in vray animation.. shikodesign2000 VRay Render 3 April 23rd, 2007 09:01 AM
Moving Objects BETO VRay Render 0 April 6th, 2006 08:27 AM
moving AEC objects only3d 3ds Max 6 September 20th, 2005 01:52 PM
I have a problem with moving objects t.fzr 3ds Max 2 June 2nd, 2005 01:46 PM
