Old June 3rd, 2008   #1 (permalink)
Name: Anwar Fardullah
Singapore
Default hologram projection
hi guys,
i was trying to figure how to create the vertical hologram projection effect with mr, any ideas?
from the real-life examples, a mixture of different colors are projected, creating the translucent shape of the object.
mesht is offline
Old June 4th, 2008   #2 (permalink)
Justin Hunt's Avatar
Default Re: hologram projection
Technically a hologram is a volumetric effect, so depending on how difficult you want to make it, try the parti-volume shader
Id rather play with mapping the image onto a plane with varying levels of opacity and translucency.
jhv
Justin Hunt is offline
Old June 4th, 2008   #3 (permalink)
shaneis's Avatar
Even those savvy folks at ILM do it in post but if you're up for the challenge of doing it with mental ray, all the best.
Here's a link to a quick "how-to" guide using After Effects.
http://www.computerarts.co.uk/tutori...hologram_scene
shaneis is offline
Old June 4th, 2008   #4 (permalink)
Singapore
thx for the link
maybe i'll try the 2 methods first, see how it goes. if it's too difficult, then do it in post
mesht is offline
LCD vs Projection Brian Smith Off Topic 1 May 31st, 2006 03:57 PM
Stereoscopic Projection System thinice Hardware and Technical Discusions 2 March 27th, 2006 05:35 PM
Rectangular projection in VizRender? thevinylgibbon AutoCAD/AutoCAD Architecture 1 January 5th, 2006 07:16 AM
Reflect Projection frigor Lightscape 0 September 4th, 2003 01:47 AM
Projection animation Sawyer General Discussions 4 August 21st, 2003 01:12 AM
