| Autodesk Revit Autodesk Revit |
Name: Raymond Salmon |
its hard to draw leaders straight like in ortho mode also they will not snap or trim or extend to anything ... guess I am used to the luxury of ADT
in drafting view to do detail dwgs... how do you get leaders to align with anything... r |
Name: Kris McIsaac |
Do you mean the leaders attached to text? if so these should always snap to horiz and vert. and your text will align with other text which will then make your leaders align but you cant use the align tool on leaders.
sorry, but i don't see this happening..
when i pick the start place for the leader (the arrow point) the leader will not go into an ortho mode even with the shift down and it will not go perpendiculat to a line. right now i just eyeball the thing but this is sorta sloppy.. r |
do you have angular snaps turned on
settings - snaps - tick the box for angular snap and add/delete set angles as required (works like the polar settings in Autocad) To add angles use a colon ; |
| I can't draw ortho. | Timothy Saunders | Autodesk VIZ | 5 | July 27th, 2006 01:24 PM |
| Lines not straight | eddie57 | AutoCAD/AutoCAD Architecture | 8 | December 2nd, 2005 10:41 AM |
| straight lines & other stuff | NOOXY | Cinema 4D | 0 | July 4th, 2005 02:44 PM |
| Cand draw line | kris | 3ds Max | 1 | December 10th, 2004 02:03 PM |
| rendering w/ straight verticals? | quatermain | Lightwave | 4 | April 7th, 2003 04:53 AM |
