You might as well try but from Joel's experience here it might not be possible to mod the 8800GT with the current tools.
I did the 8800GTS to FX4600 mod and the 8600GT to FX1700 and got some good results. |
Name: Mark Cronin |
Its a bit more difficult with vista 64 too. Since the last service pack, disabling verified drivers is more difficult? Still looking for an easy solution.
Name: Jonas Callewaert |
unless you are a gamer i see no reason not to
Not entirely true - I already did an 8800GTS and it worked. It's also supposed to work on the GTX. GT is a different, newer core, so maybe it doesn't work. My 8800GTS (AKA FX4600) and my coworker's 8600GT (FX1700) are performing a fair bit better in OpenGL than before.
Since we all thought it didn't work on the 8800GTS (NV84 core), then they came up with a workaround, I'm assuming the GT (NV92) will get one eventually. That NV92 is similar to what's in an FX3700. |
#9 (permalink) | |
