Old June 9th, 2008   #11 (permalink)
Xephir's Avatar
Germany
Default Re: time spent for projects
Originally Posted by nodar1978 View Post
no some time I need to make a texture to use it in scene, textures which is not in library.
after fynal renderings i need to do some work with photop some time, to change some small mistakes, or britness, or things like this.
how long do you think these renderings will take from you? I meen the renderings i uploaded here
Renderings like yours i've never made before. I only make outdoor viz. But if u want u can visit my website to take a look at my works. I'm a rookie actually. Low money budget and nearly everthing handmade.
System - Notebook: Intel Core 2 Duo @ 2,0 Ghz ; 4,0 GB Ram ; Geforce 8600M GT @ 512 MB Ram ; Win XP
Software: Auto Cad - Architectural Desktop 2006 ; VIZ Renderer ; Easy Nat (Plants, Trees, etc.)
Xephir is offline
Old June 9th, 2008   #12 (permalink)
nodar1978's Avatar
Netherlands  Send a message via Skype™ to nodar1978
yes nice work, do you work with vray?
I've got now one project for outdoor, in germany, 5 floor and 2 floor are diferent the first 3, and 3 antry, how do you think how much can i charge for it? they giving me the 2d archicad drawings. also i have to do some landscape, not complicated but...
www [dot] rihpex [dot] com
nodar1978 is offline
Old June 9th, 2008   #13 (permalink)
Xephir's Avatar
Germany
Thanks. Do u really think so (about my works)? No, i dont work with Vray. Only AutoCad 2006 / VIZ + Paintshop Pro XI are in use by me.
About question two: You've got a mail!
Xephir is offline
Old June 9th, 2008   #14 (permalink)
Name: Hemant Maheshwari
Hi I think For Me I Need 15-18 hours For Modelling And rendering.....
Thanks And Regards
Hemant
mayamax is offline
Old June 9th, 2008   #15 (permalink)
amer abidi's Avatar
hi Amer
i don't think so that render farm will make same rendering in 3 min as my pc doing it in 45 min. I have acces to render farm as well, but for one frame (still rendering ) thay take same time as my pc. so .....
they rendered for me one frame and it took about 2 hour, same on my pc.
Hi Nodar,
The render farm is mine, and so with distributed Rendering i have 44 xeon processors rendering one frame (at the same time), so actually it would take less than 3 minutes to render assuming you have a quad ofcourse.
And well, Yes, i do believe it would take me less than 6 hours to finish that scene. At the end of the day, you asked a question, and i gave you my personal answer. I'm not saying i'm the standard, but I know what i'm talking about
"Well I figure it has to be bigger than smaller. Whats the point of designing a concept the size of a hot dog stand? "
J.G.
amer abidi is offline
Old June 9th, 2008   #16 (permalink)
nodar1978's Avatar
hi
could you give me the web adress please, some time i need render farm service
thanks
Originally Posted by amer abidi View Post
Hi Nodar,
Old June 9th, 2008   #17 (permalink)
amer abidi's Avatar
like i said, it's mine (as in for our office work only). we don't rent it out, but if you're ever in a tight spot, drop me an email and if it's free, then by all means will help you out.
But i can't urge you enough...once you get some savings together..invest in one, no matter how small, and then keep adding to it as time goes by. It took me a lot of time, money and hard work to pull it together, but the fast turnovers now really make up for all the hard times spent pulling it together!
J.G.
Old June 9th, 2008   #18 (permalink)
Tommy L's Avatar
hi Amer
Distributed rendering. I have 32Ghz and 32g Ram working on one rendering. As I mostly do stills, this is probably about 8 times what you have on board your PC. 45/8= 6mins rendertime for your 45.
I think the 6 hours modeling sounds about right if well planned. I spend a long time on materials though.
Tommy L is offline
Old June 9th, 2008   #19 (permalink)
One thing is for sure George, Clients will take the Piss if you let them. I suspect the woman also has a little of the interior designer in her, Spotting the fact that there where no flowers, and for that one little change, could be hours of work, if you then have to find the right flowers, alter materials, make proxies, do more light calculations, and more rendering....or even worse, run into rendering problems.
When I saw the thumbnail of your image, i thought the colours/images looked a little cartoony, but when i opened the image, I thought, Bloody Hell, you have done well to get that done in 16 or so hours... I think that even if you spent a further 16 hours doing all the changes, The end result would only be say 10% improvement, and if thats what they want and are prepared to pay,then fine. Some will just keep requesting changes, as a delay tactic, maybe some do it on purpose, SO THEY CAN BREAK OUT OF THE CONTRACT(its all down to the contract), Perhaps clients need to be taught the Law of dimminishing returns.
I have been in the same boat, and I am sure many people here have.
johnvid is offline
Old June 9th, 2008   #20 (permalink)
nicnic's Avatar
^ I agree.
Set a strict number of reviews on your image, anythign after the 2-3 or so stages and its a variation which you could do on a hourly rate or whatever you agree on.
You could do one at modelling stage with a white material to agree on geometry and camera angles. Then a first textured / lit version, some feedback then onto final lighting/texturing and post production.
Make it a clear process and explain it with example images and tell your client the kind of feedbback you need at each stage, otherwise uneducated clients tend to go on a flower and cushion arranging rampage.
I would say 16 or so hours is fine for those images. Amer must be VERY FAST to do that image from scratch in 6 hours!
Dont sell yourself short or be afraid when communicating with the client, if you take the lead and offer suggestions help out then you will have a easier time doing the work. Remeber these clients are coming to you to help them at something you are an expert at, take the initiative and they will have more confidence to let you do teh work without meddling.
nicnic is offline
my first time with vray..... Neellss Finished Work 9 April 28th, 2006 11:38 AM
Is Saving Irradiance Map Helps Lower Rendering Time? odi120522 VRay Render 2 April 25th, 2006 12:10 PM
Greetings all-quasi first time post...Please be gentle kwerch General Discussions 0 March 25th, 2006 01:06 PM
reflections are killing rendering time d7man2000 VRay Render 21 February 11th, 2006 05:09 PM
First Time Night Rendering Diver Finished Work 1 December 13th, 2004 10:10 PM
