3ds Max Autodesk 3ds Max
Old June 9th, 2008   #1 (permalink)
Default HELP! Modeling a capitonnč (tufted) panel in max!
Good morning ...
I know, looong time no post... lots of things to do... also my first daughter
I am not very experienced in modeling... but now I need to model a capitonnč leather panel.. for an interior shot of a shop...
I've searched the net for a tutorial (polymodeling i suppose) but neither...
I've also used a displacement map, but I don't get it right...
someone can help me , please ?
attached is a photo sample of what I need
thanks in advance
Gabriella
Gabriella_A is offline
Old June 9th, 2008   #2 (permalink)
manta's Avatar
Default Re: HELP! Modeling a capitonnč (tufted) panel in max!
http://www.cgarchitect.com/resources.../tutorial7.asp
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old June 9th, 2008   #3 (permalink)
Thanks for the reply...
I also know this tutorial... but the panel is sligthly different from the one I have to model.. and modeling with patches is really a pain for me...
In addition the tutorial here is not complete... does not show how to create the seams between the bottons...
I was thinking that with box modeling or polymodeling was simpler and with minor polycount...
no one know other methods??
thanks again
GA
Old June 9th, 2008   #4 (permalink)
mattclinch's Avatar
England  Send a message via MSN to mattclinch
paint a nice displacement map, then just tessellate a block and use the displace modifier. hell of a lot quicker than cutting and shifting geometry - you'd be here all week.
Matt Clinch
Arch Viz Artist @ Hayes Davidson
http://www.hayesdavidson.com
mattclinch is offline
Old June 9th, 2008   #5 (permalink)
Check out this link. It shows how to model the leather buttons.
http://www.cgarchitect.com/vb/28881-...rniture-4.html
jophus14 is offline
Old June 10th, 2008   #6 (permalink)
Thanks to all
the "russian" method is interesting... but quite complicated...
finally I've drawn a displacement map.. quite nice result...but not for closer look.
No one has other modeling suggestion?
thanks again
Gabriella
Old June 10th, 2008   #7 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
if you make/find a displacement map of this please post it for us?
Antisthenes is offline
Old June 11th, 2008   #8 (permalink)
This is the final displacement map I used... (i made it from scratch)
totally seamless...
worked quite good for me, but I think that for closer looks a model shoul be better
hope that can help someone
GA
Old June 11th, 2008   #9 (permalink)
nazcaLine's Avatar
Peru
gabriella, check my post in the link jophus14 provided...there i attached some pictures of my method to model such an object, it's far simpler than the russian method and it works quite well, look at this theater view i just finished, it has some cushion panels:
"I have nothing to do with the real world anymore. Please don't insist."
Eduardo Romero
nazcaLine is offline
Autodesk to split Max 2009 into two offerings 3dmillermeter General Discussions 42 February 16th, 2008 08:53 AM
accuracy of 3ds max modeling xueming 3ds Max 2 December 11th, 2007 04:00 PM
AutoCAd modeling vs Max Modeling muzzy General Discussions 4 September 18th, 2003 08:56 AM
Modeling: AutoCAD into Max Jet General Discussions 5 May 31st, 2003 11:03 PM
modeling for LS vs MAX HeDaCoM Lightscape 4 May 19th, 2002 07:31 AM
