Go Back   CGarchitect.com > 3D SOFTWARE > 3D Tree & Plant Software and Anything Vegetation
3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum.
Old June 9th, 2008   #1 (permalink)
nelpiper's Avatar
Name: nelson fernandes
Default oxytrees flicker
Hi guys. I'm doing an animation where I have lots of onyxtrees and bushes. Unfortunately, they're flickering a lot. Does anyone have any ideas how to fiz this? Thanks.
nelpiper is offline
Old June 9th, 2008   #2 (permalink)
WAcky's Avatar
Default Re: oxytrees flicker
Are you using custom textures for the leaves? Is anything else in your scene flickering? What renderer are you using?
Give us some more info...
James Burrell
Pixel Constructions
WAcky is offline
Old June 9th, 2008   #3 (permalink)
nelpiper's Avatar
Custom leaves. I'm using vray. Just vegetation is flickering.
nelpiper is offline
Old June 9th, 2008   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
what are your sampling and AA settings in Vray? ...also, are you using UNC paths for the mapping of the leaves?
travis schmiesing
Old June 9th, 2008   #5 (permalink)
nelpiper's Avatar
Yes UNC. AA are adap subds: -1/2, ir: medium 40/30, lc:1000
nelpiper is offline
Old June 9th, 2008   #6 (permalink)
nelpiper's Avatar
what settings would be recommended for a nice free flickering rendering animation? Thanks.
nelpiper is offline
Old June 9th, 2008   #7 (permalink)
Is your lighting precalculated? Or are you generating new Irradiance maps for each frame?
In the vegetation-heavy animation I finished a few weeks ago, the key wasn't so much the individual AA/GI settings as it was precalculating my lighting.
RobNJ73 is offline
Old June 9th, 2008   #8 (permalink)
nelpiper's Avatar
I'm calculating ir and lc separate. My mistake, the are no texture for the leaves. Just pure color.
nelpiper is offline
Old June 10th, 2008   #9 (permalink)
nelpiper's Avatar
I've made another test and no trees or bushes are generating or receiving GI. It's exactly the same thing what makes me think that GI is not the problem. So, if GI is not the problem, any ideas what could it be? Thanks.
nelpiper is offline
Old July 15th, 2008   #10 (permalink)
This might be a little late but how is your DR set up? If one machine isn't seeing what the others are seeing, then it might be the problem....
Hope you found the problem-Gary
gangle is offline
AO flicker bug? STRAT Cinema 4D 1 February 25th, 2008 04:15 PM
GI Flicker Problem daveb867 Mental Ray 1 August 25th, 2007 08:15 PM
Big problem w/ Flicker sedus69 Work in Progress (WIP) 2 October 19th, 2006 05:18 AM
Flicker in vray animation, need urgent help pradipta VRay Render 8 August 30th, 2006 05:09 AM
Rendering Flicker In Animation? Claudio Branch General Discussions 5 May 15th, 2006 05:47 PM
