Go Back   CGarchitect.com > 3D CAD SOFTWARE > Autodesk Revit
Autodesk Revit Autodesk Revit
Old June 10th, 2008   #1 (permalink)
RAYMOND's Avatar
Default Display aspect ratio
use Revit on high res 9:16 screen
but notice that square is actually a rectangle
this could be calibrated in autocad but see no option in for this in Revit.. in elevation especially doors look a lot wider than they are...
I tryed also some screen adjustments but no..
r
RAYMOND is offline
Old June 10th, 2008   #2 (permalink)
Default Re: Display aspect ratio
what is your screen res? can you set it to 1680x1050? I am using a 22" wide screen with this setting and it looks fine.
kris McIsaac is offline
Old June 10th, 2008   #3 (permalink)
Ky Lane's Avatar
Yeah, its your screen res. Set it wider.
Ky Lane is offline
Old June 10th, 2008   #4 (permalink)
RAYMOND's Avatar
ok, my adventure for tommorro
however, i do remember several setting and
and circles still look like eggs...
RAYMOND is offline
Old June 11th, 2008   #5 (permalink)
RAYMOND's Avatar
well, looks like res is the answer
however my screen is 14 x 9 (not that huge i guess)
but the res setting 1280 x 1024
which is not the same ratio.
not sure how one get ratio's the same
which would make squares squares
r
RAYMOND is offline
Old June 28th, 2008   #6 (permalink)
Richard McCarthy's Avatar
r
Sounds like a hardware problem. What brand is your monitor? Normally, you don't need to install driver for monitor - it should just work properly out of box, let you pick the correct resolution. If you have a wide screen monitor, set it to the HIGHEST NATIVE RESOLUTION (should be in your monitor manual under hardware specification section).
Basically, it sounds like you have a wide screen monitor, but you run it in the incorrect 4:3 resolution hence it makes circle looks like ellipse. If you set it to the correct native resolution (either 16:9 or 16:10), it should be the proper perfect circle, and square will be square.
Some proper 16:9 resolutions :
1280 × 720
1366 × 768
Some proper 16:10 resolutions :
1280 × 800
1440 × 900
1680 × 1050
1920 × 1200
2560 × 1600
http://en.wikipedia.org/wiki/Computer_display_standard
Don't mess with my hat !!
Richard McCarthy is offline
Old June 30th, 2008   #7 (permalink)
RAYMOND's Avatar
don't see where u set the native res at...?
r
RAYMOND is offline
Old June 30th, 2008   #8 (permalink)
AJLynn's Avatar
Where you set the monitor resolution in the Display control panel, under Settings. Drag it all the way to the right. Alternatively, look up your monitor's resolution, and set it to that.
AJLynn is offline
Old June 30th, 2008   #9 (permalink)
RAYMOND's Avatar
Red face Re: Display aspect ratio
the settings are all the way to the right
however how can setting be reset to the monitors res
the menu says 1280 x 1040 which is the same as the properties
see no way to do that in display properties...
also tried the menu on the monitor itself... but all one can do is just align the display...still ellipeses for circles
maybe it be the driver...
r
RAYMOND is offline
Old June 30th, 2008   #10 (permalink)
AJLynn's Avatar
I mean, actually look up the data from the manufacturer that says what the monitor's resolution should be.
AJLynn is offline
Vray animation resolution ipxstudios VRay Render 32 March 29th, 2008 01:41 AM
Determining Pixel Aspect Ratio Jeff Mottle General Discussions 9 July 25th, 2007 07:48 AM
Widescreen Aspect Ratio IceAged 3ds Max 6 August 8th, 2006 07:14 AM
frame aspect ratio for NTSC broadcast edub Cinema 4D 7 April 5th, 2005 10:59 PM
pixel aspect ratio issues Ernest Burden Compositing Software 5 August 5th, 2004 01:00 AM
