Old June 16th, 2008   #11 (permalink)
nicnic's Avatar
Default Re: how to maintain silicon gird in facade
wot wot wot are you on about?
if you are having troubles seeing the texture from a distance, turn off blur in the bitmap, put it at 0.1 and make sure you copy the tile map into your bump channel that should fix it.
looks like you worked it out anyhow.
nicnic is offline
Old June 16th, 2008   #12 (permalink)
AJLynn's Avatar
You are correct, I do not understand the problem. The image looks like if you ran it at higher res with your final render image sampler settings the butt joint lines would come through, and if they didn't you could do what Nic said. Other than that I think what you'd be better off working on would be the textures - the curbs, the glass itself, the cladding, the grass...
AJLynn is online now
Old June 17th, 2008   #13 (permalink)
well aj sorry for all it
but i think i couldnt explain perfectly to you
so i think i have to drop my qus.
and sorry for all
and i still have my qus. remain so
can u give me your mail id i just want to mail you file
because i dont think i can explain you
and best luck for final challange
designozz3d is offline
Old June 17th, 2008   #14 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
If you model or displace your reveal lines, you can accentuate them pretty easily by using a VrayDirt map with a small radius in the diffuse.. that will stay visible QUITE a bit further than trying to use a high lighting setting.
not really a substitute for quality faking it, but it can work in a pinch
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Is it possible to model a facade like this? pailhead 3ds Max 9 July 11th, 2006 01:24 AM
