Go Back   CGarchitect.com > 3D SOFTWARE > 3D Tree & Plant Software and Anything Vegetation
3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum.
Old June 18th, 2008   #11 (permalink)
Default Re: GrowFX for 3ds Max 64-bit.
Hi!
2 quizzy
or if you want to render without opacity mapped bitmaps
Why? We have created specially for this standard leaves, they contain 1,2,3 etc. polygon.
Mesh parameters--> Add-->Standard leaves
We will later give examples ...
2 Chad Warner
Did anyone get this to work in Vray?
Demo Version Limitations
The 30-day trial version of GrowFX includes all features available in the registered version but with the following limitations:
- The possibility of converting to Editable Mesh is off;
- The GrowFX object can't be copied;
- You can't create more than 5 paths;
- Not rendering in VRay, finalRender, Brazil and Maxwell Render etc.
Limit is offline
Old June 18th, 2008   #12 (permalink)
Chad Warner's Avatar
OK, so for the full version, Vray rendering is supported?
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old June 18th, 2008   #13 (permalink)
Yes, of course!
We tested GrowFX with plugins V-Ray and Maxwell Render.
Also, we have tested his work and compatibility with finalRender and Brazil.
We have received a positive result in all cases!
Limit is offline
Old June 18th, 2008   #14 (permalink)
quizzy's Avatar
Originally Posted by Limit View Post
Hi!
2 quizzy
well yeah thats what I meant, without opacity mapped leaves and branches, its all polygons if you choose to. Which I like. In GI opacity mapped leaves and such are taking much longer to render as raw polygons.
the demo version limitation of supporting brazil, vray and some other renderers is due to the multi-res mesh and being able to convert the tree into a editable mesh during render time. multi-res meshes can give some problems with several renderers...
The demo version was not rendering in brazil but was in scanline and even mental ray
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 18th, 2008   #15 (permalink)
Ky Lane's Avatar
Cool, so what discount do we get?
Ky Lane is offline
Old June 19th, 2008   #16 (permalink)
Michiel Quist, thank you for your comments!
To purchase and obtain discounts, please contact to support@exlevel.com
Eduard Danilov is offline
Old August 1st, 2008   #17 (permalink)
BrianKitts's Avatar
Is there a pricing plan in place to allow for upgrades with future releases of 3dsmax, or will you be forcing everyone to repurchase you application with each release of max?
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old August 1st, 2008   #18 (permalink)
If you buy GrowFX now (version 1.0), all other 1.x upgrades are for free!
We will support all the future releases 3dsMax!
Exlevel is offline
GrowFX for 3ds Max - the new system of plants modeling 3dmillermeter General Discussions 0 April 11th, 2008 05:04 PM
3ds Max 9 - File Corruption mrucereto 3ds Max 2 December 27th, 2007 08:22 PM
ram and 64/32 bit? STRAT Hardware and Technical Discusions 5 November 30th, 2007 09:55 AM
64 Bit Max 6 Vince Paske Hardware and Technical Discusions 14 February 22nd, 2004 06:26 AM
3ds MAX and W2K SP 4/Hot Fix Issues Jeff Mottle 3ds Max 16 October 10th, 2003 12:07 PM
