Old June 15th, 2008   #1 (permalink)
Name: Khaled Haj Hussein
Default Photographic exposure vs Logarithmic
Hi,
I was wondering what you guys' preference is between the two, for both interior and exterior scenes.
A friend of mine told me that Mr photographic exposure should be used for outside only, is he right or wrong?
In that case, is it ok to use Mr Photographic with standard lights, in say, a fairly closed room?
hendrix2430 is offline
Old June 15th, 2008   #2 (permalink)
Justin Hunt's Avatar
Default Re: Photographic exposure vs Logarithmic
mr photographic all the way
your friend is sadly mistaken, it works fantastically for interiors. Only thing to remeamber is to try the unitless physical scale, and set your own according to the types of lights being used. As a recomended practice use the photometric lights and or the mrsun and sky system
jhv
Justin Hunt is offline
Old June 15th, 2008   #3 (permalink)
Thanks a lot for the advice!
I must say, I love Mental Ray!
Old June 16th, 2008   #4 (permalink)
Interesting stuff about the physical scale...
I've been using the exposure (EV) to help brighten up my scenes but never really played around with the physical scale yet. It's currently on physical units (default).
Bring the unitless number (now at 1500) up or down would also be a tool to brighten/darken the scene?
Old June 16th, 2008   #5 (permalink)
SandmanNinja's Avatar
You can also drop the decay on the lights, too.
I've been told going as low as 1.5 is acceptable, but not below 1.5
My last scene was rendered with decay at 1.8 and it brightened it so much and didn't (seem) to introduce noise.
-SandmanNinja
website
SandmanNinja is offline
Old June 16th, 2008   #6 (permalink)
Thanks, I'll try this out too.
By the way, has anyone purchased the mental bout max videos?
Great stuff it seems...I'm wondering though (and if Brian Brandley could chime in that would be great):
Since I'm a max 2008 user, which of the "interior lighting setup" contained in "how to series" should I purchase?
Would it be redundant to purchase the M2, M3 and M4 in addition to the M7 and M8?
Old June 16th, 2008   #7 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
can you explain this a little more...??
travis schmiesing
crazy homeless guy is offline
Old June 16th, 2008   #8 (permalink)
Brian Bradley's Avatar
Hi Khaled,
Happy to chime in if asked.
In essence all of them are relevant. The earlier videos go
more in depth on a few things such as Photon set up and
the daylight system, but also cover some non lighting material.
The Max 2008 ones bring some of the workflow upto date
using the improved toolset in Max 2008/09 such as the
Sky Portals.
Hope that helps a little, please feel free to PM or email
me if you need any extra help.
regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old June 16th, 2008   #9 (permalink)
Basically by using unitless it is possible to specify a physical scale ala log exposure.
I must admit I dont fully understand physical scale, some days it all makes sence others not so much
For exteriors I use cdm2 and for interiors unitless
jhv
Old June 16th, 2008   #10 (permalink)
Thanks Brian!
That's what I thought. The max 9 videos seem to cover a bit more ground, which is always useful.
Great site for us mental ray users.
Originally Posted by Brian Bradley View Post
Hi Khaled,
Sky Portals.
regards
Bri
MR Animation Exposure EXR's ? Spacelord Mental Ray 0 February 27th, 2008 06:30 PM
Why is the default highligh = 0,2 for "mr photographic exposure control"? robkar97 Mental Ray 5 February 7th, 2008 02:43 PM
washed out textures with mr photographic exposure control? robkar97 Mental Ray 2 February 3rd, 2008 09:04 AM
Logarithmic Exposure and Reflection conflict Cocytus09 Autodesk VIZ 4 November 3rd, 2004 03:13 PM
Radiosity, Logarithmic Exposure Control, and Bitmaps Matthew Boorstin Autodesk VIZ 6 July 1st, 2002 01:31 AM
