currently have a interior swimming pool scene, with daylight system, sky portals at windows
i want my pool to have refractive caustics, i believe i have set everything up correctly but getting the infamous "no photons stored after emitting . . . . ." error message is there something i need to do to my sky portals when caustics is enabled. i have caustics enabled on my swimming pool water surface, the daylight system and also in the render scene setup. i am using photographic exposure with final gather and NO gi |
Name: John Barrow |
Cant you set up the scene with Direct lights for the caustics?
Did you sort out your text animatin problem, I posted a response but the system lost the post, Really you needed to elaborate, pictures would be a help. |
i guess i could use direct lights but i want to be able to use the daylight system with sky portals. it must be possible???
the weid thing is, if i use the same setup but on an exterior (basically same but without sky portals or walls and ceiling) the caustics work, like on an exterior pool. i'l update the text animation post with some images, but will need to draw some sketches and scan them in. with regards to the text animation. if you imagine a cardboard box being unfolded so that it lies flat on the floor, i want to be able to animate it folding back up again. the only problem is i don't want to do it with a box, i want to be able to do it with text. i've attached an image using a box as an example. eventually i want the text to look like each letter is made from cardboard,and has been put together like a cardboard box as shown in the example image. |
#4 (permalink) | |
Name: Jeff Patton |
1. Ensure your materials are properly configured to work with photons. 2. Ensure your geometry is properly configured to generate photons. 3. If you're wanting the mrSun to generate photons GI and/or caustic, use the photon targeting option of the mrSun. Now, knowing that it's absolutely possible to setup a caustic scene with the mrSun & skylight portals, you have to decide if it's worthwhile. Perhaps simply using a caustic projection map on a light would provide decent results with faster render times, more control, and less hassle. |
#6 (permalink) | ||
Name: Jeff Patton |
For example, here's a few similar real world photos of indoor pools I found on a quick google search. I'm not seeing such a strong/pronounced caustic pattern on the ceilings: http://www.lakeviewrise.com/DSCF0043.JPG http://456js.co.uk/Images/SwimmingPoolB.jpg http://image012.mylivepage.com/chunk...20pool%207.JPG I know the point of your question isn't whether or not the reference image caustic pattern is physically accurate. It's that you simply want a caustic pattern to reflect from your swimming pool. I only mention the point about reality because once you solve the "no photons stored" issue in your scene, if photon caustics don't show up (or they aren't powerful), this may be why. I could be completely wrong in my assumption here, but I think the person that created your reference render used a caustic projection map since that strong/clear pattern doesn't seem natural to me with the amount of sunlight in that room...so you may want to focus on that route. A while back I remember seeing a few tileable caustic patterns on some website. I'll dig through my bookmarks to see if I saved it. |
Name: John Barrow |
THere is a program to export a 3Dmodel to flat paper for printing and cutting out to make a paper model, maybe you could use that to get the topology of what you want ? i think there is a program can't remember the names 3D Unfold or Something??
There is also a plugin for after effects that creates caustic patterns, you can then use those as a texturemap for the projection, the beauty of this method is you could also alter the rgb channels of the caustics separating them by slight amounts to give you a little chromatic dispersion instead of white. I think the other comments are right the pool area may be too bright to get those caustics, they are also very well defined would like to know the settings on that, true caustics would not be created in the shaded areas of the water, so perhaps just one omni above the pool would sufice as the generator, never tried caustics with photons.... can anyone tell us if you get a better result that way or no difference??? |
Name: John Barrow |
UNFOLD3D is the name of the program, though there must be a way to do it without it, maybe you had the right idea all along, with the texture map flatten thing, perhaps all you needed to do was simplify the spline for the font.
| Computer Problem? Need Help? Check Here First! | Greg Hess | Hardware and Technical Discusions | 7 | August 22nd, 2008 05:38 PM |
| nurbs problem?? | to_po | 3ds Max | 1 | August 9th, 2007 02:06 PM |
| Vray Interior wine glass problem | claytonjamesblack | VRay Render | 9 | June 19th, 2007 01:29 AM |
| File Link Problem... | demo38 | 3ds Max | 0 | April 13th, 2005 10:50 AM |
| Video Card problem? | Jeff's Friend | Hardware and Technical Discusions | 12 | September 11th, 2003 05:33 AM |
