Hello,
Question is: is there any plugin for lightwave 9+ that "drops" object on "ground". Example: I have problem with house / car where they are not on ground and i its to complicate for me now to correct their position so I was wandering if there is any plugin that solves that problem? Thanks in advance Haze. |
There are a couple of solutions. In Modeler you can pess F3 to rest an object on the ground on any or all axis. F2 centers the object at the origin.
And there is some Layyout function that does this but I can't think of the name right now. But you can check out these plugins: http://www.flay.com/GetDetail.cfm?ID=1556 http://www.flay.com/GetDetail.cfm?ID=1414 http://www.flay.com/GetDetail.cfm?ID=1934 Cheers, Florian
www.florianvonbehr.de |
Thanks Limbus for reply.
I need this methode in layout. For that plugin i will check it but seems people are not that happy with it. I need more testing but i am close to deadline so its little complicated for now Cheers, Haze. |
| Ground plane overexposed when using VRAY sun | parker2740 | General Discussions | 2 | May 14th, 2008 08:23 AM |
| fore ground images for exteriors | zombie | General Discussions | 3 | September 10th, 2006 10:30 AM |
| Back ground panaroma's w/ trees | Aaron2004 | Autodesk VIZ | 1 | May 1st, 2006 06:54 PM |
| [help 3dsmax] How to reflect on the ground | treddi | 3ds Max | 4 | March 14th, 2005 12:18 PM |
| Is there a way to drop "block" on Z-Axis only? | Richard McCarthy | SketchUp | 0 | May 10th, 2004 12:35 AM |
