Old June 19th, 2008   #21 (permalink)
SandmanNinja's Avatar
With Mental Ray and mrPhotographic settings, these are all valid guidelines.
With Mental Ray, since it's just "math" following a "forumula", you can punch in an ISO of 32 or 16 - it doesn't really exist in the real world, but it will have the same effect mathematically.
-SandmanNinja
website
SandmanNinja is offline
Old June 20th, 2008   #22 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Originally Posted by daveb867 View Post
maybe this is what you were after homeless_guy
This is perfect.... Well almost perfect. It would be nice if it had White Balance on the roll out also.
travis schmiesing
crazy homeless guy is offline
Old June 21st, 2008   #23 (permalink)
glad i could be of assistance
only problem is i don't know how to use it.
does this mean that you don't need to use the mrphotographicexposure anymore, can we leave that deactivated and just adjust the exposure per camera???
and due to the fact there is no white balance control on the cam, then how would you get around that? PS maybe??
daveb867 is offline
Old June 22nd, 2008   #24 (permalink)
actually, i only had a chance to install it. my initial reaction was that it was the solution to the problem, but on closer inspection, it actually is not. i read Zap's blog post about it, and he clearly outlined that he created the script because this is where he felt the information needed to be rather than the environment roll out. he also made it clear that the script he created simply called the ones in the environment, and was in no way a solution, but more of a concept.
here is the basics of how his the script works...
you go to the camera create panel as you normally would. if you have the script installed, there will be an option to create a mr camera. you create that, and the camera controls are then part of the modifier tab. you can adjust the shutter speed, f-stop, ISO and a couple of other things.
the shutter speed, f-stop, and ISO in the modifier panel are scripted to change the information in the environment roll out. when you change the number here, it changes the number in the mr photographic exposure settings in the environment roll out. so yes, you need that enabled.
i was wrong in saying you could not control the white balance. since you still use the mr photographic exposure enabled, the white balance is still in place.
where this script fails for me... it is not on a per camera basis. i was hoping that the camera settings were attached tot he camera. if it was on a per camera basis, then when you switched cameras, the f-stop, shutter speed, ISO would all change to the settings needed for that camera.
to me this script suggests that a per camera might be possible if i had a little knowledge in the scripting department. which i do not.
travis schmiesing
Old June 23rd, 2008   #25 (permalink)
ah sorry, was worth a shot anyway, my bad for not reading (or understanding) the blog post in the first place
daveb867 is offline
Old June 23rd, 2008   #26 (permalink)
well i don't consider wasted time by any means. to me it appears that there might be a way to pull this off through scripting. i may be easier to use the 'basis optmize exposure photographic' shader by Thorsten Hartman to achieve it though. i really need to learn Max scripting.
travis schmiesing
Old June 23rd, 2008   #27 (permalink)
United_States  Send a message via AIM to Camby1298 Send a message via MSN to Camby1298
Its not Max scripting in this case that you need to know. Its how to develop mr shaders for this specific instance. There are many tutorials on the web on how to develop shaders; I'll have a look into it as well.
Camby1298 is offline
Old June 23rd, 2008   #28 (permalink)
Possibly, it would certainly give you more options. That is how the BO script is set up, but Zap clearly states that he called the existing MR Photgraphic controls via scripting, not by developing a new shader. It is a '.ms' file, and not a '.mi' file.
http://mentalraytips.blogspot.com/20...h-dof-and.html
travis schmiesing
Old June 23rd, 2008   #29 (permalink)
So true, but one of the best features of mr is the ability to customize it per user (hence why it is used vasly in the VFX field). But by developing your own mr Camerea shader you can include those features found in the mr Photograph Exposure plus any other custom features.
I wish you would say this to my face
mental ray standalone now available vizwhiz General Discussions 7 July 17th, 2008 06:53 PM
Mental Ray and Vray Proxies Usability Compared crazy homeless guy Mental Ray 10 April 24th, 2008 05:29 PM
Maya v. Mental Ray Shaders hd_leach Maya 3 May 9th, 2007 12:13 PM
Max 7 Lights with Mental Ray OllyNicholson 3ds Max 9 July 21st, 2005 02:13 PM
