Go Back   CGarchitect.com > 3D CAD SOFTWARE > Autodesk Revit
Autodesk Revit Autodesk Revit
Old June 19th, 2008   #1 (permalink)
Default Flip control on level head?
We use a half circle for our level elevations. We flip this when two are close and conflict on the drawings.
We're just starting with Revit, and I've made a custom level head buble but I would like to be able to put flip control on it. It's not available at the side as a tool when editing the level head family.
Can anyone help?
Thanks,
3dway is offline
Old June 25th, 2008   #2 (permalink)
Richard McCarthy's Avatar
Default Re: Flip control on level head?
I don't think Level head can have flip control on it.
The way around it is to use parametric visiblity function to toggle it.
eg. Set up two sets of level head however you want it, select the first group > element property > graphics tab > visibility , then the button besides visibility (square button)> add parameter. Call it "Up" level head (or whatever you want), and do the same for the other group except name it "down" level head. Save the Family as family parameter as oppose to Shared parameter. Now once you start using the new level head, you can goto level head's element property menu, edit > and then select either up or down.
Don't mess with my hat !!
Richard McCarthy is offline
Exposure COntrol PER camera Camby1298 Mental Ray 2 June 16th, 2008 03:56 PM
color halftone control awdb0404 General Discussions 0 November 18th, 2005 01:28 PM
Animating spline control points? AJLynn Cinema 4D 3 July 23rd, 2005 04:25 PM
Skydomes v's exposure control Jim Mann 3ds Max 2 May 20th, 2003 03:29 AM
script: RPC RGB level control quizzy Scripts 0 June 3rd, 2002 06:05 AM
