Go Back   CGarchitect.com > 3D CAD SOFTWARE > Autodesk Revit
Autodesk Revit Autodesk Revit
Old June 19th, 2008   #1 (permalink)
Default spiral stairs
Does any body know how to create a spiral stair in revit?
diablo is offline
Old June 20th, 2008   #2 (permalink)
Lithuania
Default Re: spiral stairs
Yes
whori is offline
Old June 20th, 2008   #3 (permalink)
So how do you make the spiral stairs?
diablo is offline
Old June 20th, 2008   #4 (permalink)
Lithuania
i think you should read tutorials that comes with revit..
Creating Spiral Staircases Revit Architecture 2009 User's Guide > Working with Architectural Components > Stairs >
  1. Open a plan or 3D view.
  2. Click Modelling menuStairs, or on the Modelling tab of the Design Bar, click Stairs.
  3. Click Set Work Plane on the Design Bar to select a different work plane. See Sketching and Work Planes.
  4. On the Options bar, click .
  5. In the drawing area, click to select a center point for the spiral.
  6. Click a start point.
  7. Click an end point to complete the spiral.
    Completed spiral staircase
    The spiral is limited to fewer than 360 degrees. If you overlap spiral runs, a warning is displayed; stringers and railings are not placed accurately.
TipTo create a spiral staircase to multiple levels, create one helix for the stairs and then copy that helix to the appropriate levels.
whori is offline
Old June 20th, 2008   #5 (permalink)
Thanks, I did not see that
diablo is offline
Old June 20th, 2008   #6 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
I couldn't help but think of Pavement when I read Spiral Stairs.
http://www.matadorrecords.com/presto...l_of_industry/
travis schmiesing
crazy homeless guy is offline
Animating Escalator Stairs? visualmusic.4 General Discussions 6 November 9th, 2007 07:34 AM
Spiral Stairs done for local revit group logo contest Razorback Autodesk Revit 9 September 18th, 2007 01:52 AM
Creating stairs and measuements conflicts Arnold Grove 3ds Max 6 July 19th, 2007 11:41 AM
Stairs Lyle AutoCAD/AutoCAD Architecture 2 March 29th, 2006 09:43 PM
railings in spiral stair in viz ecastillor Autodesk VIZ 1 March 18th, 2005 07:00 PM
