Old June 24th, 2008   #1 (permalink)
Default Rhino and Vray
Who out there are using this combo for Arch Vis and getting great results...?
I have been using Rhino for almost 3 years and am very reluctant to switch to 3ds Max (even though I have a copy of 8)
I just find Rhino way more user friendly.
What with Vray and other programs being developed to work/plugin with Rhino and Rhino's ability to create almost any shape - with Vray as the rendering package will it look the same as a model rendered with Vray from Max...???
Im not too sure of the advantages that Rhino has over 3ds Max or visa-versa...
Also I have experienced getting some of my models up to 300mb in size and was wondering how to better handle overall panning shots that need to take in alot of info - making it harder to delete parts of the model to cut down on the chances of crashing etc...
Whats the largest model size - fully textured that some of you out there have experienced...???
SSPEIPER is offline
Old June 24th, 2008   #2 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
Default Re: Rhino and Vray
that all depends on the job
take shortcuts and use less complex geometry where you can if you are approaching models that big
i have no crashes. go ahead and upgrade the v4 for sure so you can have all the abilities of autocad in it
Antisthenes is offline
Rhino and Vray - How good is it...??? SSPEIPER Rhinoceros 4 June 24th, 2008 05:45 PM
VRay for Rhino and Sketchup: any limitations? emu VRay Render 1 November 21st, 2007 03:07 PM
I need information of Vray for Rhino autocad VRay Render 0 October 10th, 2007 07:09 PM
Vray for Rhino 4.0 brentwatanabe VRay Render 3 October 2nd, 2007 02:35 PM
Rhino and Vray manta General Discussions 12 October 4th, 2006 06:01 PM
