| Autodesk Revit Autodesk Revit |
Name: caleb abudu |
Hello. Now that revit 2009 is out. Is there any1 out there that knows if its possible to create data for shop drawings for the likes of Gherys' bilbao titanium skin facade?
couldn't you have created that anyway using the massing functions????
or even design in sketchup and bring into revit as a massing object where you can then add walls, floors, curtain systems etc, custom walls with custom materials etc. anything is possible if you know how |
He's not talking about massing, he's talking about shop drawings for the panels.
You know that architects don't have to make shop drawings?... But anyway. Create them automatically? I very strongly doubt it. You'd need something like Digital Project (the Gehry software). |
Name: Chris Holt |
I have read a lot of articles about being able to send directly to CAD/CAM from Rhino, but not Revit. I am sure we will eventually get there with that program (and the rest of the "BIM" software, but it is going to be a while!)
Name: Jonas Callewaert |
yes import from Rhinoceros
i have done it quite a few times
Rhino would also not be the right tool for the job unless you are a brilliant script writer. All due respect, Jonas, but I very strongly doubt you've done this. We're talking about thousands of metal panels, all different, with the hardware for mounting them and the structure that supports that. Each dimensioned and at a precision where you can get a shop to fabricate not a model of the building but the actual building. All of this is constrained by lord knows how many variables. The parts aren't modelled, they're defined parametrically and computed, and the casual user is not going to be able to do this.
Name: Jeremiah Spoon |
Andrew,
Don't be such a pessimist. I bet if someone tried real hard they could build it out of popsicle sticks. Scan it with a 3d desktop scanner into sketchup. Take that 3d info into archicad on a linux workstation and then generate the shop drawings form there. After that they could go polish the new york city sewer system using a toothbrush and an old pair of undies. |
Name: Richard McCarthy |
You could also try using massing to curtain wall conversion method. Then adjust the glazing panel family to suite. The problem ofcourse is to laid out individual panels and the brackets or fixings that fix it in place.
Techically, I think it is doable, if you can somehow make those panels family as "scheduable" in Revit. It would definitely a nightmare to do it by hand panel by panel, but I think a bit of creative thinking using UV unwrapping programs to "laid" out the curtain wall form flat, then draft in the details of each panels is the method I would go for.
Don't mess with my hat !! |
