Old July 1st, 2008   #1 (permalink)
andreg's Avatar
Canada  Send a message via MSN to andreg
Default render different siding colors workflow
Hi guys,
I have this client that want a few renders of the same building but with different siding colors (one render for each color). I know this is something easy to do by just replacing the maps but I was wondering if there is a trick to get this done faster than rendering each image? Would the render elements be used for something like this? Is there a quick tip that someone has and would be willing to share?
Hoping to get some feedback on this before I send them the quote.
Andre Gariepy
J27 Design and viz
http://www.j27design.blogspot.com
andreg is offline
Old July 1st, 2008   #2 (permalink)
Ky Lane's Avatar
Default Re: render different siding colors workflow
Photoshop
Make it all white, and just put an overlay layer with your fav color, or even just add a "color overlay" modifier to the layer. Would take you 2secs to change it then.
But, thats only if theres no light bouncing off it, you may need to do some speccy photoshop then.
Ky Lane is offline
Old July 1st, 2008   #3 (permalink)
andreg's Avatar
thanks... forgot about our good ol buddy photoshop. Head was too crowded to think straight on this one.
Andre Gariepy
J27 Design and viz
andreg is offline
Old July 1st, 2008   #4 (permalink)
Ky Lane's Avatar
Ky Lane is offline
Old July 1st, 2008   #5 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
you can use render elements to render out a selection mask to make it easier to select in photoshop to create the color overlay.
travis schmiesing
crazy homeless guy is offline
vray interior render drark!! meme131 VRay Render 43 April 1st, 2008 02:09 PM
gamma, net render of a batch render Justin Hunt 3ds Max 0 February 10th, 2008 04:35 PM
Network / Render times / $ ahmon Hardware and Technical Discusions 2 October 20th, 2007 09:09 AM
Render elements problem raterry 3ds Max 2 October 11th, 2007 01:14 PM
cinema 4d PiNkFlUiD Finished Work 13 February 28th, 2003 05:00 AM
