So, in the past I've used the usgs national map viewer to extract 3d topography in GeoTiff format, which i then converted via 3dem to DEM format, which i then imported into max with some free plugin I'd found online.. a bit of an evil process to say the least.
Now, i need to dig me up some topo for the LA valley and was wondering if there is any other good/reccommended ways to get it nowadays that doesn't involve a java interface from 2001 and many hours of work?
Dave. TD / EwingCole DMG |
its kind of funny, I'm basically looking for this: http://www.davidrumsey.com/GIS/losangeles3D.htm and using the same 3d engine he is too
Name: Derik Bibb |
Dave,
I get elevation data from this site: http://data.geocomm.com/catalog/US/6.../group4-3.html You can download the data for free using the green download arrows. There's a free program called sdts2dem.exe. Use that to create the DEM file. (just copy sdts2dem.exe into the folder with the elevation files and run it) I then use polytrans (not free) to import the DEM data, export to a 3ds, and import into max. I think you can also import the DEM data directly to max, but it is a super heavy mesh. Polytrans does a much better job of interpolating the data into a usable mesh. If anyone has a better/faster method than that I'd also like to know about it Hope that helps,
Derik Bibb Architectural Visualizer TANGRAM 3DS International 3D & Design Solutions |
Thanks for the info Derik, thats much easier than finding and downloading by lat/long values
I have polytrans here, albeit we bought it many years ago for a specialty project and haven't installed it in a long long while
Name: Jonas Callewaert |
Name: Andrew Schroeder |
www.landdata3d.com has a LA package on there, and currently offers 50% off with the coupon code "celebrate" (Until the 4th)
#7 (permalink) | |
Probably beats the current workflow of making terrain, and draping a cloth sim on it to get a decent quad mesh to begin editing on lol.
#8 (permalink) | |
Name: Claudio Branch |
I regularly create large terrain models with only the road surfaces using quads for texture placement. Everything else is sweet clean triangles! |
#9 (permalink) | |
I was also able to import the DEM file into AutoCAD using EasySite. ES has a routine that will create new contour lines from a set of faces and I can tell it the height interval. I can now triangulate these contours and build a terrain mesh with much lighter density wherever I need it. Furthermore, ES gives great control for integrating the rest of the modeled infrastructure (roads, parking lots, building pads, etc.). |
It doesn't really, its more for areas where i have to do heavy editing, we tend to get existing condition topography lines of dubious quality from civil guys, but are in early enough phases that we are grading/modifying the site ourselves
| 3D Studio Max & finalToon question | missheartbeat | finalRender | 1 | January 8th, 2008 02:25 AM |
| hats off to joep van der steen! and a question | SgWRX | Mental Ray | 2 | October 1st, 2007 07:01 AM |
| Question | 2serengeti | General Discussions | 11 | September 21st, 2007 08:55 AM |
| Yet another computer question: C2T7200 vs C2 E6400 | Arnold Grove | Hardware and Technical Discusions | 7 | November 26th, 2006 09:40 PM |
| simcloth question + 3ds max6 | haneet khanna | 3ds Max | 4 | November 9th, 2005 11:32 AM |
