Old July 3rd, 2008   #11 (permalink)
Tommy L's Avatar
Default Re: Field Grass using Hair and Fur
I made a field of prairie grass using vray fur. I know you want MR but if you have both then theres no reason you cant comp in post. Ive attached a small sample. This was a HUGE field of grass, between viewer and building. Rendered in no time.
Worked great in conjunction with DOF.
Tommy L is offline
Old July 3rd, 2008   #12 (permalink)
Claudio Branch's Avatar
W/ or w/o Shadows?
Claudio Branch is online now
Old July 3rd, 2008   #13 (permalink)
Tommy L's Avatar
cant remember.
Tommy L is offline
Old July 3rd, 2008   #14 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
I think I am going to try and use the Hair and Fur. I am going to set up a section, then convert it to geometry, and then make it a proxy. Below is a test of where I am at. I will wind up painting a slight orange/red tail on areas in PhotoShop afterwards, but is is slowly getting there.
This image is 900 pixels wide, and rendered in 5 minutes. Which isn't bad, but I don't have the rest of the building in the scene.
travis schmiesing
crazy homeless guy is offline
Old July 3rd, 2008   #15 (permalink)
Justin Hunt's Avatar
I think that if you break the ground plane into smaller planes it will render/ be more memory efficient than one really large plane
The grass tooks great
jhv
Justin Hunt is offline
Old July 3rd, 2008   #16 (permalink)
Ky Lane's Avatar
Nice Travis - I had a play last night and got varied results - mind sharing your settings?
Ky Lane is offline
Old July 3rd, 2008   #17 (permalink)
sure. i haven't spent a great deal of time fine tuning things, so if you make improvements, please share those also...
travis schmiesing
Old July 3rd, 2008   #18 (permalink)
Ky Lane's Avatar
Just had a play and got some real nice results, and pretty quick! This took about 90secs to render each frame (vlow settings mind you)... the crap at the bottom is just a displacement map.
Ky Lane is offline
Old July 3rd, 2008   #19 (permalink)
that is sweet looking.
travis schmiesing
Old July 3rd, 2008   #20 (permalink)
Ky Lane's Avatar
Later that day...
Ky Lane is offline
hair and fur rug daveb867 Mental Ray 0 March 4th, 2008 06:37 AM
problems in Vray fur , Hair & fur paragsm 3ds Max 7 October 15th, 2007 11:35 PM
Hair & Fur WSM memory limit? georgesvalera Mental Ray 3 June 27th, 2007 10:44 AM
Creating Grass w/ Hair & Fur Modifier... Claudio Branch 3ds Max 2 August 29th, 2006 01:36 PM
Render errors using Hair and Fur Grass Technique VTWales33 3ds Max 0 August 15th, 2006 11:41 AM
