Old July 2nd, 2008   #1 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Field Grass using Hair and Fur
Anyone have experience rendering Hair and Fur as grass using MR? I have a lot of field grass I need to render around a building, and am considering this method though the first few initial tests fell flat on their face.
I was reading something on the LA user group site about specific MR hair shaders, but it sounded like it might currently be over my head.
travis schmiesing
Old July 2nd, 2008   #2 (permalink)
TheAllusionist's Avatar
Default Re: Field Grass using Hair and Fur
Haven't tried it since Max 9 so I am not sure if it will work with current versions, but you might try SuperGrass http://www.antiflash.net/supergrass/
And the all knowing mr guru Jeff Patton has an older tutorial http://jeffpatton.net/MR_Grass_displacement.htm
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind.
3DAllusions | 3DAllusions Studio | MrMaterials
TheAllusionist is offline
Old July 3rd, 2008   #3 (permalink)
Justin Hunt's Avatar
I tried max hair and fur, it worked to a degree but just couldn't get it convincing enough. I was trying to create long, coastal grass. From what I remeamber you have to add a mr shader and set the hair to render as mr primitives, or something like that. Took ages to render though
Brian Bradley did a mentalboutmax video using hair in one of the project sceries (once again I'm going from memory) worked well
jhv
Justin Hunt is offline
Old July 3rd, 2008   #4 (permalink)
WAcky's Avatar
Mr fur for grass is annoying. Unless its for long grass like justin mentioned just comp in real grass.
Like justin mentioned i would reccommend the Mental bout max tutorial in which they make grass using fur. They did a great job with it!
James Burrell
Pixel Constructions
WAcky is offline
Old July 3rd, 2008   #5 (permalink)
Displacement is definitely not going to work. There is a couple of grass areas that range from 10" for one, and a foot and a half for the other. Right now I am working with a combination of proxies and comping in real grass in post to clean up the edges.
If I can get something like the second image on the linked site below, it might look quite nice. But I don't want to extreme render times. I am fine with it taking longer, but if it more than doubles the time required for the high res image, I am going to use something else. Right now I am at about 1-1.5 hours for a 4000x4000 wide image.
http://mentalraytips.blogspot.com/20...revisited.html
travis schmiesing
Old July 3rd, 2008   #6 (permalink)
Another option I am considering is rendering the hair and fur in scanline, and then using that to comp onto the final image.
travis schmiesing
Old July 3rd, 2008   #7 (permalink)
peterguthrie's Avatar
I would stick with proxies ;-)
The attached image was done using vrayproxies and the advanced painter script - I made 2 different 1m x 1m patches (which were made using standard max scatter and 3 grass blades) of grass and then painted them all over the terrain with random rotation and scale.
www.peterguthrie.net
peterguthrie is offline
Old July 3rd, 2008   #8 (permalink)
Claudio Branch's Avatar
The attached image was done using vrayproxies and the advanced painter script.
Agreed.
I used this very approach recently and it worked great on my stills and animation.
Claudio Branch is online now
Old July 3rd, 2008   #9 (permalink)
can i ask how you generated the grass model for the proxy? ...right now i am using modified plant leaves, generated with Onyx Flower.
travis schmiesing
Old July 3rd, 2008   #10 (permalink)
I just drew a triangle to the size I wanted it in the left viewport, then added a edit mesh modifier so that it had faces and then a bend modifier. I then collapsed each one to an editable mesh and gave each one a different material ID. I made 4 like this all a bit different and then scattered them around a plane as per the attached image.
Its best to keep the grass as low poly as possible and with no thickness so that you can use a vray2sided material (not sure what the MR equivalent is) to simulate translucency.
If you want the grass to look like it is being blown by the wind you could limit the rotation to say +- 10 degrees and again when you paint them on using advanced painter.
Hope that helps,
Peter
hair and fur rug daveb867 Mental Ray 0 March 4th, 2008 06:37 AM
problems in Vray fur , Hair & fur paragsm 3ds Max 7 October 15th, 2007 11:35 PM
Hair & Fur WSM memory limit? georgesvalera Mental Ray 3 June 27th, 2007 10:44 AM
Creating Grass w/ Hair & Fur Modifier... Claudio Branch 3ds Max 2 August 29th, 2006 01:36 PM
Render errors using Hair and Fur Grass Technique VTWales33 3ds Max 0 August 15th, 2006 11:41 AM
