3ds Max Autodesk 3ds Max
Old July 3rd, 2008   #1 (permalink)
Brian Smith's Avatar
Default Tip: How to save hundreds of MBs of RAM on large scenes without slowing rendering
I recently mentioned this tip in a class and based on the fact that no one knew it, I thought it would be worthwhile here. If you are rendering a very large scene and are getting close to running out of RAM, here's a way that will save you a few hundred extra MBs from being consumed without slowing down rendering at all like other procedures (such as rendering in dynamic mode or with proxies).
Simply save the scene in wireframe mode with one maximized viewport and reload the scene. As soon as you change to Smooth+Highlights mode, you should see a lot of RAM consumed, with more being consumed for larger scenes. If you switch to Smooth+Highlights mode before you render, you are basically giving away that RAM, and there is no way to get it back. But if you just load a scene and immediately render without going into Smooth+Highlights first, you will have all that extra RAM to render with. Open your Task Manager and monitor your RAM consumption to verify. The larger the scene, the more RAM you save. Roughly speaking, you should expect to see a savings of 100MB for every 1million polygons your scene contains.
Brian Smith
www.3dats.com
Brian Smith is offline
Old July 3rd, 2008   #2 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
Default Re: Tip: How to save hundreds of MBs of RAM on large scenes without slowing rendering
Its the little things! Nice one Brian, thanks!
"How many polygons does the real world push?"
FlytE is offline
Old July 3rd, 2008   #3 (permalink)
Claudio Branch's Avatar
Great tip, thanks!
Claudio Branch is offline
Old July 3rd, 2008   #4 (permalink)
Ray
Ray's Avatar
Thank you, Brian! Keep 'em coming.
Ray is offline
Old July 3rd, 2008   #5 (permalink)
Ok, how about this. Take it a little further. When it's time to render, go to the Display panel and in the Hide by Category rollout, select everything but Geometry. This hides all the lights, shapes, cameras extra that all consume RAM. Then select all the geometry and enable 'Display as Box'. Save then reload and you can see another few hundred MBs less RAM consumed.
Brian Smith
www.3dats.com
Old July 3rd, 2008   #6 (permalink)
odouble's Avatar
Name: Tunde Agunbiade
Really interesting... I am going to try it right now. Thanks
odouble is offline
Old July 3rd, 2008   #7 (permalink)
or use the batch renderer and eliminate the entire overhead associated with the UI....
John Dollus is offline
Old July 3rd, 2008   #8 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
close the material editor also, as those bitmaps also get loaded into ram at startup/open.
another way without reopening max to do roughly the same thing is to:
Code:
in the little pink maxscript bar at the bottom left hand corner type:
freescenebitmaps()
hit enter
gc()
hit enter again
minimize max
maximize max
Also be aware that the real memory ram usage number you're looking for isn't visible by default in the task manager, if go to View, Select Columns, and look for VM Size. thats the combined RAM+Virtual memory. if you're in max 32bit, and that number hits 1,700,000 roughly, you can kiss max goodbye slowly thats becoming less of an issue with 64bit, but not everyone has taken that plunge.
Dave.
TD / EwingCole DMG
Dave Buchhofer is online now
Old July 3rd, 2008   #9 (permalink)
I find it much easier to just monitor the Available RAM under the Performance tab.
Brian Smith
www.3dats.com
Old July 3rd, 2008   #10 (permalink)
Invalid User Profile
Ruramuq's Avatar
Name: notyourbusiness notyourbusiness either
Peru
I can't notice a difference with this tip, this memory issues seems to be more about textures and geometry :
› Global Viewport rendering settings : standard display
Max loads viewport textures only when they are visible, so, perhaps moving the viewport away would give similar memory improvements
Another thing to notice, is that if max is minimized,a big amount of 3dsmax memory will be released, or marked as free, which means that virtual memory will be used, thats the reason why I try to never minimize max when I'm working with it, (I don't want xp reading the paging file)
but even if you release a lot of memory deactivating textures, etc.. the most likely is that if the render engine needs more ram, windows will paginate automatically, and the memory used for the viewport will need to be reloaded by max when the render ends, in other words, it's likely that these tips might not be a big benefit for the render..
another thing is that big textures seems to be loaded completely, and with several textures displayed on the viewport, textures sizes matters. it is probably a good idea to reduce the texture size of objects that are far away or too little(this for render and viewports).
I tested with different color depth and it seems that there is a benefit in the viewport but not when rendering
there are a couple of tools i use
› Process explorer(much better than task manager) and › RAMpage, it displays and is able to release or defragment automatically the memory to avoid crashes.
I also read that memory fragmentation is another cause of max crashes.
my first post
Ruramuq is offline
rendering large scenes, very large scenes guyhaviv 3ds Max 3 September 30th, 2003 02:46 AM
