Old July 4th, 2008   #11 (permalink)
shikodesign2000's Avatar
Default Re: another-settings..
I'm using max8, and I haven't the option to change the value of (Vignetting)..just choose it or not..maybe it is in max9..
anyhow, can you please tell me some benefits of this option??
Best Regards,
Sherif Massoud
www.3dshore.com
shikodesign2000 is offline
Old July 4th, 2008   #12 (permalink)
vizwhiz's Avatar
Thanks again Justin for your openion, I think if I can reach the level of evermotion renders, this will be very great..but exceeding them..it'll be hard somehow
To quote Home Depot: "You can do It and we can help"
Thats what CGA is for, a global collective inclusive consciousness of 3d arch viz
(imho)
vizwhiz is offline
Old July 4th, 2008   #13 (permalink)
louis.cho's Avatar
Name: Louis Choinière
The vignetting option is in the VrayPhysicalCamera. Don't know wich version your are using but if you have the lastest it's should be there.
______________________
Louis Choiniere
www.espaceparallele.com
louis.cho is offline
Old July 4th, 2008   #14 (permalink)
WAcky's Avatar
like most things its probably better to not use vignetting in max and insert it with PS for more control.
James Burrell
Pixel Constructions
WAcky is offline
Old July 4th, 2008   #15 (permalink)
I'm using max8, and I have the vignetting option..can you tell me plz its use??
Best Regards,
Sherif Massoud
www.3dshore.com
Old July 4th, 2008   #16 (permalink)
WAcky's Avatar
Turn it off on the VrayPhysicalCamera settings.
James Burrell
Pixel Constructions
WAcky is offline
need help: saving settings as defaults daveb867 3ds Max 2 April 28th, 2008 06:18 AM
gamma settings for max 2008 and photoshop mesht Mental Ray 3 February 11th, 2008 05:16 PM
vray settings Janrey VRay Render 8 May 4th, 2007 01:07 PM
vray settings issue celticdog VRay Render 1 July 7th, 2006 11:33 AM
Raytrace Settings Wolf 3ds Max 30 July 31st, 2002 07:44 AM
