Old July 3rd, 2008   #1 (permalink)
Smile image from Libya layout animation
hi everyone,
these are the still images i cut from the animation. this project is located in Libya. in this animaition , we use some technique to pull the camera from the bottlom of the ocean to see clearly the creatures up to the surface of the ocean.
we use AMDthlon*2 2GB RAM 3DMAX V-Ray
i am looking forward to your comment.
ivi3d is offline
Old July 3rd, 2008   #2 (permalink)
Ky Lane's Avatar
Default Re: image from Libya layout animation
I think his teeth need some displacement, and theres no ground plane shadows - check your GI settings. Not sure of that green either, not very photoreaslistic, but if its the cartoon look you're after, I think you pulled it off. Well done.
Ky Lane is offline
Mapping an image onto a terrain cferman SketchUp 2 January 8th, 2008 12:04 PM
Animation Jaggies Wokka Cinema 4D 2 June 13th, 2007 03:33 AM
need tips on animation. salf 3ds Max 1 February 1st, 2006 06:25 AM
2004 CGarchitect.com Calendar Call for Submission Jeff Mottle General Discussions 6 November 27th, 2003 11:13 PM
Newbie Question: Is this image difficult to create? JAVB Autodesk VIZ 3 November 16th, 2003 01:01 AM
SEO by vBSEO 3.1.0
