Old July 4th, 2008   #1 (permalink)
birdman67's Avatar
Default Chairs_DOF study
Had a couple of hours to mess around with DOF and PS compositing..C&C welcome!
birdman67 is offline
Old July 4th, 2008   #2 (permalink)
blowback's Avatar
Default Re: Chairs_DOF study
I think it works. But .... it's a fine line with dof
When we open the box,
there is a 50% chance that the cat is alive and a 50% chance that the cat is dead
blowback is offline
Old July 4th, 2008   #3 (permalink)
Eric Sosa's Avatar
Denmark
well, yes, nice Gene....you should try withouth photoshop help, you already got the scene.
perhaps it's just me, I hate using photoshop after everysingle render.
Eric Sosa is offline
Old July 4th, 2008   #4 (permalink)
blowback's Avatar
I don't mind compositing .... sometimes you can achieve the same look quicker in photoshop / after effects than noodling in max.
blowback is offline
Old July 4th, 2008   #5 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
the chair needs more poly's.
travis schmiesing
crazy homeless guy is offline
Old July 4th, 2008   #6 (permalink)
birdman67's Avatar
Thanks for the input...it was really just a quick exercise for me to take the render elements and composite in PS with the zdepth channel/lens blur filter. I've only recently started doing renders this way because it's definately quicker (at least for me) and it affords much more control than trying to get the 'perfect render' with Vray DOF, esp when on a tight deadline. I'm basically experimenting the Chris Nichol's compositing workflow posted here:http://www.chaosgroup.com/forums/vbu...83883#poststop, except in PS.
Old July 7th, 2008   #7 (permalink)
looks cool.
can i ask a question
How do you get the focus affect you have in the first image it look really affective
craigball is offline
Old July 7th, 2008   #8 (permalink)
birdman67's Avatar
I took the render elements (color, diffuse filter, specular, raw GI, raw lighting, rawreflection) and composited them using blending modes in PS...hit it with the high pass filter for AA, then overlayed that on top. Once I got the image I wanted, I used the zdepth render element for DOF by applying it as a separate channel to the final image. Then, filter>blur>lens blur, using the zdepth channel as the source...tweaked some of the settings a bit to my liking and got this image.
Like I said before, it's really nothing new...I was just experimenting with compositing the render elements and using the zdepth for DOF. Someone mentioned rendering it straight out in Vray using DOF, and yes, that's fun too...but first of all it takes longer to render and you're stuck with what you get. I prefer using the lens blur filter in PS because it's quicker, it allows much more control of the final image, and it's easier/quicker to make any changes, at any time.
Old July 10th, 2008   #9 (permalink)
thanks for that really help full this is my Attempt http://www.cgarchitect.com/vb/attach...3&d=1215502303
Old July 10th, 2008   #10 (permalink)
birdman67's Avatar
Nice! How did you like doing it that way, post in PS?
Reflection Impact Study Justin Hunt General Discussions 4 April 3rd, 2007 04:21 PM
Sun Study Sawyer 3ds Max 5 January 4th, 2007 05:40 PM
Work and study in the UK And0 Off Topic 2 September 9th, 2006 07:41 PM
Volumetric study Zortea Work in Progress (WIP) 2 May 24th, 2004 01:09 PM
Exterior Shadow Progression Study MegaPixel 3ds Max 5 July 16th, 2003 11:26 AM
