3ds Max Autodesk 3ds Max
Old July 6th, 2008   #1 (permalink)
1rv
Chad
Default sketchup->proxy
Hi everybody!
Does anybody have a clue how to swap sketchup components exported to max for vray proxy instance?
I know about triangle faces+scattering procedure but maybe there's something more simple.
Thanks in advance.
1rv is offline
Old July 6th, 2008   #2 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
Default Re: sketchup->proxy
Not sure i follow what you're asking, but to turn an object into a VrayProxy just right click on it and go to Vray Mesh Export in the quad menu.
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Old July 6th, 2008   #3 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
I don't have an exact answer either, but I often use a SoulBurn Script called Object Replacer or something like that to replace items in scenes. I am guessing you can create a Vray proxy, set it as your object to be used for replacing in the script, then select everything you want replaced, and hit ok.
travis schmiesing
crazy homeless guy is offline
Old July 6th, 2008   #4 (permalink)
ahh that makes a little more sense yes.. I was reading the question wrong lol
Dave.
TD / EwingCole DMG
Old July 6th, 2008   #5 (permalink)
Chad Warner's Avatar
Quizzy's got one on his site that I use all the time: http://www.3idee.nl
under scripts, then "random replacer" Like the name suggests, it will randomly replace a set of objects with a predefined set of objects.
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old July 7th, 2008   #6 (permalink)
1rv
Chad
The issue:
1. I've got 50 components (houses for instance) in sketchup.
2. I export 1 of them to max and turn it into vray proxy.
3. Then I export the whole SU as .3ds and in max scene i try to swap meshes
(the remains of my su components) for proxy.
Is everything healthy in my workflow?
Many thanks SoulBurn Script Object Replacer. It works great with dwg blocks.
But with sketchup comp. meshes... max put pivots to 0,0,0, and changing to "pivots to object" does not align along meshes. Is there tool\script to solve it?
1rv is offline
Sketchup vs AutoCAD Architecture alfienoakes General Discussions 17 January 30th, 2008 02:25 AM
Sketchup to Cinema jrizzo Cinema 4D 13 January 25th, 2008 07:23 AM
Google's SketchUP Pro 5.0 Review Jeff Mottle CGA News 0 January 2nd, 2007 11:02 PM
Using Sketchup to clean up a model for LS Mark Bolin Lightscape 8 April 25th, 2004 03:08 PM
