Old July 8th, 2008   #1 (permalink)
Netherlands  Send a message via Skype™ to uhofmann
Default Problem Environmental Map rendering in Mental Ray
Hi To all,
since a few days i tried to solve a problem but i don't get the point:
Software: 3dmax 2009 design
Render: hosted Mental Ray
I want to render a house, with mr_sun and mr_sky, i added the mr_physical_Sky shader ... in enviromental render setting. this works.
But i want a picture with clouds, so í added instead of the mr_physical_Sky a bitmap with blue sky and clouds, but when i render the background is black instead of the clouds and blue sky.
Do i unterstand something wrong??
Thanks for helping
Uwe
Reality is not what you see, reality is what you Want to see.
http://www.make3d.eu
uhofmann is offline
Old July 8th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: Problem Environmental Map rendering in Mental Ray
I think you have to crank the multiplier on the output of the cloud jpg REALLY HIGH....
Just to make sure I understand, you've used a custom map in the mrPhysical Sky, right?
-SandmanNinja
website
SandmanNinja is offline
Old July 8th, 2008   #3 (permalink)
Justin Hunt's Avatar
for a full and detailed expination of whats really going on read Master Zaps Blog
http://mentalraytips.blogspot.com/
look for "Why does mental ray Render (my background) Black? Undestanding the new Physical Scale settings "
jhv
Justin Hunt is offline
Old July 8th, 2008   #4 (permalink)
Ky Lane's Avatar
What I do is, use the mrphysicalsky, and add the bitmap to the haze channel, and up the bitmaps output to between 10-20....
Ky Lane is offline
Old July 9th, 2008   #5 (permalink)
Yes custom map on mrPhysical Sky.
uhofmann is offline
Old July 9th, 2008   #6 (permalink)
Now it works - the high output solved it and you have to adjust in the bitmap/map output the RGB curve to control the kontrast and the gamma.
But the next effekt which appears in my mockup installation ist that the skybitmap dont mirrors in mirror surfaces . - funny ne?
the material on the sphere in the attached picture is chrome, you see it
reflects the basic skycolor and the ground but not the skybitmap.
uhofmann is offline
Old July 9th, 2008   #7 (permalink)
Yeah, I brought in one of the sunset panoramics from the ArchMat folder and made the multiplier 20. Not as vibrant as a HDRI, but it offers some variety over the solid blue.
-SandmanNinja
website
Old July 9th, 2008   #8 (permalink)
Ky Lane's Avatar
Well, heres my solution if interested, based on this
Sorry, 3DsMax2009Dx86 and MR...
Ky Lane is offline
Old July 9th, 2008   #9 (permalink)
So works now tried different sun settings. The only thing i didn't found realy out. how you did in the scene the lensflare.
uhofmann is offline
Old July 9th, 2008   #10 (permalink)
here also some pics
uhofmann is offline
Maya v. Mental Ray Shaders hd_leach Maya 3 May 9th, 2007 12:13 PM
Refer to the MR-section for rendering with Mental Ray - DO NOT ask in this section nisus 3ds Max 0 February 26th, 2007 05:09 AM
Problem with Mental Ray drvox 3ds Max 5 June 20th, 2006 05:30 PM
rendering using mental ray.. prashanth 3ds Max 4 September 21st, 2005 01:47 AM
Mental Ray Shadow Map Ninja 3ds Max 2 July 21st, 2004 09:49 AM
