Autodesk VIZ Autodesk VIZ
Old July 9th, 2008   #1 (permalink)
Default Backburner Questions
Is it possible to run render servers from more than one backburner manager? In other words, I have (4) machines that I run via remote desktop from my laptop. I have another machine that I would like to be able to render to the servers from as well. In the backburner settings I only see one place to enter the manager name or ip address, is there a way to add another one for the other machine I want to render from as well?
Thanks!
marksee is offline
Old July 9th, 2008   #2 (permalink)
Default Re: Backburner Questions
You should have manager running on one machine on your network. Then you can send to it from any machine on the network with a full max license. You can also connect to the monitor app from any machine.
I once tried running 2 copies of manager on one network (form differnet pcs) and the nodes got a bit confused and froze - I had to shut it all down and reboot each machine to get going again.
Macer is offline
Backburner Job Share Thox 3ds Max 0 May 23rd, 2007 03:25 AM
Overwrite Error Causing Backburner Files?? JamesTaylor Autodesk VIZ 2 April 25th, 2007 09:31 AM
Backburner & IP Address Brolloks Autodesk VIZ 2 October 18th, 2006 07:29 AM
URGENT: BackBurner issues: random picking order?? nisus 3ds Max 7 April 25th, 2006 04:43 PM
Some Radiosity Related Questions MegaPixel 3ds Max 3 August 9th, 2005 06:28 AM
