Old July 12th, 2008   #1 (permalink)
Name: marcelo bonifacio
Default 2gig of Ram?
Hi guys I always find some help here...
I had been tryng to find any post related to xp64 and 4 gigs of ram but with no luck, im rendering and my computer and it is using nearly all the prossesor power...but never more than 2 gigs in the ram department.. is a dual core with prosesor 2.6MHz with four gigs of ram.. windows xp64..and Im running max and vray 32bits.. the task bar shows all the ram but is not using it...Why?
thanks for any advise...
marcbon31 is offline
Old July 12th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: 2gig of Ram?
It will only use the ram if it needs to.
A CPU-intensive scene is not neccessisarily a memory-intensive scene.
BUT - ram is (currently) cheap and it's better to have it than not, eh?
I have an idea that if you started rendering an animation sequence of a 4+ million poly scene with 36 lights, with shadows and reactor moving 50+ trees, that your ram usage would go up.
-SandmanNinja
website
SandmanNinja is offline
Old July 12th, 2008   #3 (permalink)
you mentioned max and vray 32bits. could it just not be addressing more than the 2gb b/c they are 32bit? oh - maybe not because you can address up to 3gb on xp 32bit machine?
SgWRX is offline
Old July 12th, 2008   #4 (permalink)
Ky Lane's Avatar
While this thread attracts those in the know.. can anyone explain to me how my 32bit Vista installation see's all 4Gb of my Ram?
Ky Lane is offline
Old July 12th, 2008   #5 (permalink)
Because it's Vista and it's "rounding up"?
Seriously, I wouldn't put it past Microsoft to 'round up', to avoid questions from thousands of people.
And it's true - there is 4 gigs of ram in your machine.
[does a Google]
ah ha.
http://answers.yahoo.com/question/in...2125328AAX8DU0
For 2 people who say I should see all mem - i heard in latest Vista service pack, it shows amount of physical installed memory, not amount of available.
-SandmanNinja
website
Old July 12th, 2008   #6 (permalink)
WAcky's Avatar
because its vista and not XP...
James Burrell
Pixel Constructions
WAcky is offline
Old July 13th, 2008   #7 (permalink)
Ky Lane's Avatar
[does a Google]
ah ha.
Thats bulk dodgey.
Ky Lane is offline
Old July 14th, 2008   #8 (permalink)
I am sorry I could not answer before... but my machine is 64bites... the memory shows up but is not been used....????
Old July 15th, 2008   #9 (permalink)
kippu's Avatar
why are you using 32 bit max on 64 bit machine and secondly ...try a huge scene with lots of meshes and displacement ,proxies and see if its using up the 4 gig memory
www.renderviz.com
kippu is offline
Old July 20th, 2008   #10 (permalink)
Name: Benoit SaintMoulin
Belgium
The RAM amount displayed by Windows is direclty from the Bios information.
Eg. If you have 4 GB RAM and Bios only display 3.2 GB, Windows only display 3.2 GB, but if you BIOS display 4 GB, Windows diplay 4 GB, so in 32 mode he only use 3.2 GB RAM maximum, the rest as the motherboard permit is automatically allocated to shared PCI device.
Sometimes with 4 GB on 32bits system you can get more free ram for your applications as system us the upper allocated to shared device (PCI, PCIe, IRQ,...)
SO in 32 Bits system applications is limited to 2 GB per applications ! but you can force application to use more than 2 GB with the Boot switch /3GB (put is in boot.ini at the end of line)
eg. "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Wind ows XP Professional Edition" /noexecute=optin /fastdetect /3GB"
I hope that's usefull for you.
Best,
Ben
bsm3d is offline
Tip: How to save hundreds of MBs of RAM on large scenes without slowing rendering Brian Smith 3ds Max 25 July 29th, 2008 07:20 AM
Server Ram Vs Desktop Ram Rconce01 Hardware and Technical Discusions 13 May 9th, 2008 10:55 AM
Virtual Ram voltaire_ira Hardware and Technical Discusions 0 February 27th, 2005 10:16 PM
afraid of RAM joseph alexander Hardware and Technical Discusions 2 August 26th, 2004 07:29 AM
