Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old July 14th, 2008   #1 (permalink)
Bewdy's Avatar
Default Slice Script
Hi, I'm looking for a script which will automate a process which I seem to do a lot of.
I'm often having to double slice poly's at very regular intervals, (so that I can extrude the double sliced polys) usually for modeling mortar joints, creating tile patterns, brick coursing that sort of thing.
I'm guessing there must be a script for this somewhere, I've had a quick look on some script sites, but I thought I'd ask here, as someone may be doing exactly this sort of things as well.
Ideally, I'd like to be able to set two different slice offsets, (or a single slice offset and the distance of the second slice from the first) and a count for the number of slices across the object.
Failing that, is there a function in Max to record an action, and then play it back so one button will do multiple functions, much the same as the way photoshop does?
Cheers for any help.
Matt Sugden
Business http://www.virtual-living.co.uk
Pleasure http://www.icompositions.com/artists/OnIt
Bewdy is offline
Old July 14th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: Slice Script
Yes, it's called script listener.
I make quick and dirty scripts all the time.
Just:
1) get the 'thing/action to script' ready to go
2) right click on script listener and make sure it's enabled and 'clear' of existing script
3) do the action
4) save the script listener to a file
5) open that file in the script editor
6) highlight the text in the editor and drag it to a tool bar
7) name it "Matt's Cool Script #1"
I use this all the time to help with editing the face of a poly for greebling.
I inset, extrude, etc and then I can click on any face (no matter if the face is bigger or smaller than the original face) and click a button, and I have an IDENTICLE 50-step greeble applied to that face.
Hope that helps
-SandmanNinja
website
SandmanNinja is offline
Old 7 Hours Ago   #3 (permalink)
Bewdy's Avatar
sorry to bring this thread back from the dead. While trying to 'record' the function of a slice in the script listener nothing appears to be happening in the pink or white sections of the MAXscript listener.
In fact when I do anything, nothing appears to be recorded in the max script listener, I must be doing something wrong. I have maxscript listener ticked F11, and I also have it set to 'enabled'.
Any ideas?
Matt Sugden
Bewdy is offline
populate script Koper 3ds Max 3 March 11th, 2008 04:43 AM
Slice Modifier changes mesh ITryMyBest 3ds Max 0 August 2nd, 2007 12:45 PM
Max Script..... hmahesha Scripts 3 March 9th, 2007 06:11 AM
Rendering large images - what's the script? Rick Eloy 3ds Max 13 May 31st, 2006 12:46 AM
script: Random material ID quizzy Scripts 2 April 22nd, 2006 03:04 AM
