Go Back   CGarchitect.com > 3D SOFTWARE > 3D Tree & Plant Software and Anything Vegetation
3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum.
Old July 16th, 2008   #1 (permalink)
nelpiper's Avatar
Name: nelson fernandes
Default vue xstream
Hi guys. Does anyone here use vue? Is it as good as everybody says? It beats onyx? Thanks.
nelpiper is offline
Old July 16th, 2008   #2 (permalink)
Default Re: vue xstream
If your using it for animation the render times can get very high! You can have crazy amounts of polys, ive pushed it to nearly 20 billion. The actual tree/foliage models are just as good as onyx, it really comes down to what will fit into your pieline/hardware setup.
If you want a quick way of placing trees etc try proxy painter http://www.3rdpole.com/
Showreel - http://thatch.cgsociety.org/gallery/
thatch is offline
Old September 11th, 2008   #3 (permalink)
floraworks's Avatar
New Zealand
yep i use vue 6 do not use solid growth plants though because they suck try importing 3d models such as xfrog trees etc
floraworks is offline
Integration between 3ds max9 an d vue pradipta General Discussions 4 February 20th, 2008 12:30 PM
E-on Software Ships Vue 6 Easel, Esprit And Pro Studio Jeff Mottle CGA News 0 March 14th, 2007 12:13 AM
E-on Software Ships Vue 6 xStream and Vue 6 Infinite Jeff Mottle CGA News 1 February 22nd, 2007 08:25 PM
Vue 5 or Vue 5 xstream? Bugga_Guy General Discussions 9 October 19th, 2006 09:50 AM
Vue 5 & Autodesk VIZ 2005 Scott Baumberger Autodesk VIZ 0 January 7th, 2005 10:00 AM
