#11 (permalink) |
Name: travis schmiesing |
In my spare time I have been working with mapping of layers out of Revit into 3dsmax, but don't have any definitive results yet.
The problem, or at least what I am currently considering the problem, is that the geometry feels heavy regardless of whether it is a FBX or DWG. That being said, I found this script a couple of days ago that I have not tried out yet. I think it will drop the 'parent' problem that is created on files comping out of Revit. It is designed to be used with importing a DWG and not linking a DWG, but if you follow AutoDesks recommended workflow, it involves importing a FBX. So I am hoping I can import a FBX, then use this script to ditch the parenting, with the hopes that ditching the parenting will make the file less taxing on the processor and video card. Like I said, it is only a thought right now, but to me, it sounds like it might make sense. When I get a chance, I am going to toy with using it both on a FBX and DWG. http://www.scriptspot.com/3ds-max/dwg-cleanup .
travis schmiesing |
| Tags |
| fbx |
| FBX export from Sketchup to Max 2008 | Tomass | 3ds Max | 5 | June 22nd, 2008 07:32 AM |
| fbx import problem | Billabong | 3ds Max | 0 | November 26th, 2007 11:59 AM |
| FBX from 3dsMax | skala67 | General Discussions | 0 | September 14th, 2005 11:20 AM |
| Quicktime's FBX | Chaz | Realtime/VR/ Interactive/ VRML | 1 | February 27th, 2005 01:32 PM |
