Old July 20th, 2008   #1 (permalink)
Luxembourg
Default how many buckets on 8 core ?
Hy
I'm just testing a new workstation 8 cores Intel Mac-Pro
on rendering with Max 2009, Vray Sp2 on Xp64, the task manager shows 50 CPU usage ?
and on rendering the image there is only 4 buckets, should it not be 8 buckets for 8 cores ?
lyca is offline
Old July 20th, 2008   #2 (permalink)
Ky Lane's Avatar
Default Re: how many buckets on 8 core ?
I get 8...
Ky Lane is offline
Old July 20th, 2008   #3 (permalink)
Luxembourg
Originally Posted by Ky Lane View Post
I get 8...
are you using xp or vista ?
lyca is offline
Old July 20th, 2008   #4 (permalink)
Ky Lane's Avatar
Vista64
Ky Lane is offline
Old July 20th, 2008   #5 (permalink)
Name: Nick Glazebrook
It's a setting - don't remember, either vray or max need to be told to use 8 or all cores (max threads or similar).
NG
NickG is offline
Old July 20th, 2008   #6 (permalink)
Luxembourg
thanks guys, i found it, i was using a project created on a quadcore,
when reset vray it works
lyca is offline
Old July 21st, 2008   #7 (permalink)
be sure that if you are using the Light Cache in VRAY to set your "passes" to the number of cores in your machine.
This will speed up this part of the pre-rendering process...
Adam
BOXXlabs
BOXXLABS is offline
Old July 22nd, 2008   #8 (permalink)
Luxembourg
[quote=aglick@boxxtech.com;217317]be sure that if you are using the Light Cache in VRAY to set your "passes" to the number of cores in your machine.
thanks for the advice, must i set it to the total of cores rendering in the network (4x2xquad cores xeon) or just the total of the local machine (2xQuad) ?
lyca is offline
Old July 22nd, 2008   #9 (permalink)
AJLynn's Avatar
The machine.
AJLynn is online now
Core 2 Duo VS. Dual Core Xeon padhia Hardware and Technical Discusions 15 March 28th, 2008 08:46 PM
DR Buckets Geoffc VRay Render 3 June 14th, 2007 03:36 PM
Dual Xeon slower than dual core alfienoakes Hardware and Technical Discusions 16 May 22nd, 2007 02:19 PM
Dual core v quad core Liza Hardware and Technical Discusions 5 January 17th, 2007 10:13 AM
Dual core can render 4 buckets in Vray? sin81 VRay Render 25 June 6th, 2006 04:47 AM
