| Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications. |
we need to redo an old animation with 4:3 aspect ration to 16:9 with some changes to the actual animation. Now the problem is that when we change the aspect, the actual 3D objects comes closer to view, which we don't want. ----- You can see this when you put a box in your scene, set the aspect to 1.333, turn on safe frames and change the width of the image output size by draging the slider.
I have been told that there is a script that would change the camera focal length according to the aspect ratio so that the object "stays" (wrong word to use) in place. was that a clear discription? anyone knows? |
| Objects are locked | Maxer | 3ds Max | 11 | April 29th, 2008 11:45 AM |
| Autodesk 3ds Max 2009 and Autodesk 3ds Max Design 2009 Now Shipping | Jeff Mottle | 3ds Max | 25 | April 1st, 2008 06:58 PM |
| Autodesk to split Max 2009 into two offerings | 3dmillermeter | General Discussions | 42 | February 16th, 2008 08:53 AM |
| Canon G5 camera and camera matching | pailhead | Hardware and Technical Discusions | 4 | February 24th, 2004 12:08 AM |
| 3ds MAX and W2K SP 4/Hot Fix Issues | Jeff Mottle | 3ds Max | 16 | October 10th, 2003 12:07 PM |
