Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old July 21st, 2008   #1 (permalink)
Koper's Avatar
Name: AdriaaN van Jaarsveld
South Africa
Default 4:3 to 16:9 in max with camera focal length
we need to redo an old animation with 4:3 aspect ration to 16:9 with some changes to the actual animation. Now the problem is that when we change the aspect, the actual 3D objects comes closer to view, which we don't want. ----- You can see this when you put a box in your scene, set the aspect to 1.333, turn on safe frames and change the width of the image output size by draging the slider.
I have been told that there is a script that would change the camera focal length according to the aspect ratio so that the object "stays" (wrong word to use) in place.
was that a clear discription?
anyone knows?
_____________________
AvJ
www.nationalgraphix.com
Koper is offline
Old July 21st, 2008   #2 (permalink)
Netherlands
Default Re: 4:3 to 16:9 in max with camera focal length
overscan
scriptspot.com
Gus_Rayvus is offline
Old July 21st, 2008   #3 (permalink)
Koper's Avatar
South Africa
Peter!! You are the MAN!!
Thanx A Million!
AvJ
Koper is offline
Objects are locked Maxer 3ds Max 11 April 29th, 2008 11:45 AM
Autodesk 3ds Max 2009 and Autodesk 3ds Max Design 2009 Now Shipping Jeff Mottle 3ds Max 25 April 1st, 2008 06:58 PM
Autodesk to split Max 2009 into two offerings 3dmillermeter General Discussions 42 February 16th, 2008 08:53 AM
Canon G5 camera and camera matching pailhead Hardware and Technical Discusions 4 February 24th, 2004 12:08 AM
3ds MAX and W2K SP 4/Hot Fix Issues Jeff Mottle 3ds Max 16 October 10th, 2003 12:07 PM
