Old July 21st, 2008   #1 (permalink)
nelpiper's Avatar
Name: nelson fernandes
Default sata hd strange behaviour
I have a WD RAPTOR 36GB and a SEAGATE BARRACUDA 7200.9. My SATA SEAGATE is connected to sata 1 port and my WD RAPTOR is connect to the sata 2 port. When this is the case, the system boots fine and everything is nice and neat. When I invert the the hard drives, there is, the seagate on sata 2 and the raptor on sata 1 it says: BOOT FAYLURE, PLEASE INSERT SYSTEM DISK. Does anyone have any ideas why this behaviour? Would it be something in the bios? Thanks.
nelpiper is offline
Old July 21st, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: sata hd strange behaviour
The BIOS is trying to boot the wrong disk. The solution is:
-Don't change which hard drive is plugged in where.
Or:
-When you change this, also change the boot disk setting in the BIOS.
AJLynn is offline
Odd spinner behaviour markf 3ds Max 2 January 31st, 2008 02:44 PM
new workstation alikashan Hardware and Technical Discusions 22 April 10th, 2006 11:39 AM
some strange CPu problems haneet khanna Hardware and Technical Discusions 1 July 20th, 2005 09:16 PM
Strange artifacts in radiosity rendering Saturn Autodesk VIZ 4 April 16th, 2005 05:26 AM
Need advice on SATA New Hardware and Technical Discusions 0 September 5th, 2004 11:10 PM
